how to enter Bootloader mode
Hi, Nordic
I check this: devzone.nordicsemi.com/.../ , first, it will work when I follow this article. Then I have 2 questions:
  1. it said "If the bootloader LED is not lit, try pressing Button 4 during startup, this will put the device into bootloader mode".
    where can I found these code? (press button 4 to enter to bootloader mode)
    If I want to change the way to enter bootloader mode, how can I do?
    after DFU done, when I download new bootloader, it show "ERROR: The area to write is not erased.", this time, if I want to update bootloader, only can DFU?
  2. I check, when DFU done, bootloader->app, now APP is running, can I add code to make nRF52 enter to bootloader mode? If yes, how can I do?
Plz help me. Thanks.
  • If you're using the bootloader in SDK v12.x.0 then you will find the code in the nrf_dfu_enter_check() function in the nrf_dfu.c file. However, note that this is only done once on startup, i.e. you have to hold the button while you turn on the device.
