When i use ble_app_hrs to connect with hrs demo(ble_app_hrs example), everything is ok.But when i connect to a heart rate monitor, it always disconnect.The print information is:
[DM]: Disconnect Reason 0x0008
[DM]: --> device_context_store
[DM]:[DI 00]:[CI 00]: -> No update in bonding information.
[DM]: --> gattc_context_store
[DM]: Notifying application of event 0x12
[APPL]: >> DM_EVT_DISCONNECTION
[DM]: >> dm_whitelist_create
[DM]: Created whitelist, number of IRK = 0x00, number of addr = 0x01
[DM]: << dm_whitelist_create
[APPL]: << DM_EVT_DISCONNECTION
[DM]:[CI 0x00]: Freeing connection instance
[DM]:[00]: Freed connection instance.
[DM]: Initializing Connection Instance 0x00000000.
[APPL]: 180d
[DM]: Request to allocation connection instance
[DM]:[00]: Connection Instance Allocated.
[DM]: Searching for device 0xB6 0x99 0x7F 0x04 0xA5 0x78.
[DM]:[DI 0x00]: Device type 0x00.
[DM]: Device Addr 0xB6 0x99 0x7F 0x04 0xA5 0x78.
[DM]: Found device at instance 0x00
[DM]:[00]:[Block ID 0x0003F800]:Loading bond information at 20002f14, size 0x0000001C, offset 0x00000018.
[DM]:[0x00]:[0xFF]: Bond context Event
[DM]: Notifying application of event 0x21
[APPL]: >> DM_EVT_LINK_SECURED
[APPL]: << DM_EVT_DEVICE_CONTEXT_LOADED
[DM]:[00]:Loading service context at 20002f30, size 0x0000000C, offset 0x00000034.
[DM]: --> gattc_context_load
[DM]: Notifying application of event 0x11
[APPL]: >> DM_EVT_CONNECTION
[APPL]:[B6 99 7F 04 A5 78]: Connection Established
[DM]: >> dm_security_setup_req
[DM]: << dm_security_setup_req, 0x00000000
[APPL]: << DM_EVT_CONNECTION
[DM]: >> BLE_GAP_EVT_CONN_SEC_UPDATE, Mode 0x01, Level 0x02
[DM]: --> gattc_context_apply
[DM]: Notifying application of event 0x15
[APPL]: >> DM_LINK_SECURED_IND
[DB]: Starting discovery of service with UUID 0x180d for Connection handle 0
[APPL]: << DM_LINK_SECURED_IND
[DB]: Discovery of service with UUID 0x180d completed with success for Connectionhandle 0
[DB]: Starting discovery of service with UUID 0x180f for Connection handle 0
[DB]: Discovery of service with UUID 0x180f completed with success for Connectionhandle 0
[HRS_C]: Heart Rate Service discovered at peer.
[HRS_C]: Configuring CCCD. CCCD Handle = 19, Connection Handle = 0
[HRS_C]: SD Read/Write API returns Success..
Heart rate service discovered
[BAS_C]: Battery Service discovered at peer.
[APPL]: Battery Service discovered.
[APPL]: Reading battery level.
[BAS_C]: SD Read/Write API returns error. This message sending will be attempted again..
[APPL]: Enabling Battery Level Notification.
[BAS_C]: Configuring CCCD. CCCD Handle = 46, Connection Handle = 0
[BAS_C]: SD Read/Write API returns Success..
[APPL]: Battery Level Read as 100 %
Battery = 100 %
[APPL]: Battery Level received 100 %
Battery = 100 %
What is the problem? Thanks
i use sniffer to get the information below:
This is the error information:
This is the heart rate monitor connect with iphone 6(ios 9.3), that is ok
the information file is wireshark format: the err device file:ble_hrm_err.pcapng the ok device fileble_hrm_ok.pcapng
than with the demo "ble_app_hrs_c" of "nRF51_SDK_10.0.0_dc26b5e" and there are something different,when i change the "MAX_CONNECTION_INTERVAL" from "MSEC_TO_UNITS(30, UNIT_1_25_MS)" to MSEC_TO_UNITS(130, UNIT_1_25_MS) after the time increase, i can get a hrm data like this:
Heart rate service discovered Battery = 80 % Battery = 80 % Heart Rate = 73 Heart rate service discovered Battery = 80 % Battery = 80 % Heart Rate = 77
i think there may be some params is error, but i cann't find it.
