I2C with Softdevice nrf_drv_twi_enable hangs
Using SDK 12.1.0
I2C with SoftDevice works on PCA10040 Eval Board with nRF52832 but hangs in the nrf_drv_twi_enable function with TY module EBSGCNZWY which is an nRF51822 version F1. Running without the SoftDevice on the TY module, the I2C works fine.
  • I would write the UICR register in the code (as it is erased whenever the SoftDevice is downloaded), check how it is done in the uicr_config example.
    You should connect a logic analyzer or an oscilloscope to the lines and see what is going on in hardware. At this point I do not know what is the cause of your problem.
