How to check for pending interrupts before calling sd_app_evt_wait?
Hi. I am having trouble getting the sd_app_evt_wait() call to work correctly in my code. My main program works like this:
<inits>
for(;;)
   <read saadc>
   <sd_app_evt_wait> // app_timer should make this return in 10 seconds
I have an app_timer that causes sd_app_evt_wait to return by firing every 10 seconds. The problem is, after sampling the ADCs, the call to sd_app_evt_wait returns immediately, running the loop forever. It doesn't sleep and wait for the timer. If I put a second call to sd_app_evt_wait directly after the first, the first call returns, and the second call sleeps until the timer wakes it (desired operation, but with two calls). From what I have learned of the sd_app_evt_wait function, if there are pending interrupts, it will immediately return. However, if I read the NVIC->ISPR at any time, it is 0. No interrupts pending, but sd_app_evt_wait returns once, then sleeps properly, on the Second call. I read about the FPU interrupts, so I added the following:
 uint32_t FPU_EXCEPTION_MASK = 0x0000009F;
pending = __get_FPSCR();
if (pending)
	NRF_LOG_DEBUG("FPU Exceptions: %d\r\n", pending);
	/* Clear exceptions and PendingIRQ from the FPU unit */
	__set_FPSCR(__get_FPSCR() & ~(FPU_EXCEPTION_MASK));
	(void) __get_FPSCR();
	NVIC_ClearPendingIRQ(FPU_IRQn);
but they don't help. The variable "pending" is always 0, and the ISPR is always 0. Adding
NVIC_ClearPendingIRQ(SAADC_IRQn);
before the first call to sd_app_evt_wait doesn't help either. What am I missing?
  • If you migrate your whole project to SDK 13, you don't have to worry about these things. They were meant as a guide if you wanted to use the SAADC driver from SDK 13 in your SDK 12.1 project. There are logging in SDK 13, and it implements some new functions/macros that was not available in SDK 12, to simplify the module logging process. I suggested commenting out log-functionality, as the functions are not present in SDK 12.1, and it you will get compile errors.
