I'm a user of nRF52 DK with S132. I want to modify the event handler in the example application code such as ble_uart_c. Where can i find the full list and description of events that S232 stack support ?
You can find our API documentation here. Not sure what you want to do, but I recommend looking at the message sequence chart for the given procedure to know what events you should handle.
Thank you so much. Let me try to do the way that you mentioned.
Have a nice weekend.
As I needed the same thing and it took me some time to compile the List, I am posting it here in case anyone needs the same list:
//This list was taken from nRF SDK 17.1 from the S132 header files
//It is useful for looking up events if they are only known
//as decimal or binary numbers
BLE_EVT_INVALID = 0 (0x0)
enum BLE_COMMON_EVTS
BLE_EVT_USER_MEM_REQUEST = 1 (0x1), /**< User Memory request. See @ref ble_evt_user_mem_request_t \n Reply with @ref sd_ble_user_mem_reply. */
BLE_EVT_USER_MEM_RELEASE = 2 (0x2), /**< User Memory release. See @ref ble_evt_user_mem_release_t */
enum BLE_GAP_EVTS
BLE_GAP_EVT_CONNECTED = 16 (0x10), /**< Connected to peer. \n See @ref ble_gap_evt_connected_t */
BLE_GAP_EVT_DISCONNECTED = 17 (0x11), /**< Disconnected from peer. \n See @ref ble_gap_evt_disconnected_t. */
BLE_GAP_EVT_CONN_PARAM_UPDATE = 18 (0x12), /**< Connection Parameters updated. \n See @ref ble_gap_evt_conn_param_update_t. */
BLE_GAP_EVT_SEC_PARAMS_REQUEST = 19 (0x13), /**< Request to provide security parameters. \n Reply with @ref sd_ble_gap_sec_params_reply. \n See @ref ble_gap_evt_sec_params_request_t. */
BLE_GAP_EVT_SEC_INFO_REQUEST = 20 (0x14), /**< Request to provide security information. \n Reply with @ref sd_ble_gap_sec_info_reply. \n See @ref ble_gap_evt_sec_info_request_t. */
BLE_GAP_EVT_PASSKEY_DISPLAY = 21 (0x15), /**< Request to display a passkey to the user. \n In LESC Numeric Comparison, reply with @ref sd_ble_gap_auth_key_reply. \n See @ref ble_gap_evt_passkey_display_t. */
BLE_GAP_EVT_KEY_PRESSED = 22 (0x16), /**< Notification of a keypress on the remote device.\n See @ref ble_gap_evt_key_pressed_t */
BLE_GAP_EVT_AUTH_KEY_REQUEST = 23 (0x17), /**< Request to provide an authentication key. \n Reply with @ref sd_ble_gap_auth_key_reply. \n See @ref ble_gap_evt_auth_key_request_t. */
BLE_GAP_EVT_LESC_DHKEY_REQUEST = 24 (0x18), /**< Request to calculate an LE Secure Connections DHKey. \n Reply with @ref sd_ble_gap_lesc_dhkey_reply. \n See @ref ble_gap_evt_lesc_dhkey_request_t */
BLE_GAP_EVT_AUTH_STATUS = 25 (0x19), /**< Authentication procedure completed with status. \n See @ref ble_gap_evt_auth_status_t. */
BLE_GAP_EVT_CONN_SEC_UPDATE = 26 (0x1a), /**< Connection security updated. \n See @ref ble_gap_evt_conn_sec_update_t. */
BLE_GAP_EVT_TIMEOUT = 27 (0x1b), /**< Timeout expired. \n See @ref ble_gap_evt_timeout_t. */
BLE_GAP_EVT_RSSI_CHANGED = 28 (0x1c), /**< RSSI report. \n See @ref ble_gap_evt_rssi_changed_t. */
BLE_GAP_EVT_ADV_REPORT = 29 (0x1d), /**< Advertising report. \n See @ref ble_gap_evt_adv_report_t. */
BLE_GAP_EVT_SEC_REQUEST = 30 (0x1e), /**< Security Request. \n Reply with @ref sd_ble_gap_authenticate \n or with @ref sd_ble_gap_encrypt if required security information is available. \n See @ref ble_gap_evt_sec_request_t. */
BLE_GAP_EVT_CONN_PARAM_UPDATE_REQUEST = 31 (0x1f), /**< Connection Parameter Update Request. \n Reply with @ref sd_ble_gap_conn_param_update. \n See @ref ble_gap_evt_conn_param_update_request_t. */
BLE_GAP_EVT_SCAN_REQ_REPORT = 32 (0x20), /**< Scan request report. \n See @ref ble_gap_evt_scan_req_report_t. */
BLE_GAP_EVT_PHY_UPDATE_REQUEST = 33 (0x21), /**< PHY Update Request. \n Reply with @ref sd_ble_gap_phy_update. \n See @ref ble_gap_evt_phy_update_request_t. */
BLE_GAP_EVT_PHY_UPDATE = 34 (0x22), /**< PHY Update Procedure is complete. \n See @ref ble_gap_evt_phy_update_t. */
BLE_GAP_EVT_DATA_LENGTH_UPDATE_REQUEST = 35 (0x23), /**< Data Length Update Request. \n Reply with @ref sd_ble_gap_data_length_update. \n See @ref ble_gap_evt_data_length_update_request_t. */
BLE_GAP_EVT_DATA_LENGTH_UPDATE = 36 (0x24), /**< LL Data Channel PDU payload length updated. \n See @ref ble_gap_evt_data_length_update_t. */
BLE_GAP_EVT_QOS_CHANNEL_SURVEY_REPORT = 37 (0x25), /**< Channel survey report. \n See @ref ble_gap_evt_qos_channel_survey_report_t. */
BLE_GAP_EVT_ADV_SET_TERMINATED = 38 (0x26), /**< Advertising set terminated. \n See @ref ble_gap_evt_adv_set_terminated_t. */
enum BLE_GATTC_EVTS
BLE_GATTC_EVT_PRIM_SRVC_DISC_RSP = 48 (0x30), /**< Primary Service Discovery Response event. \n See @ref ble_gattc_evt_prim_srvc_disc_rsp_t. */
BLE_GATTC_EVT_REL_DISC_RSP = 49 (0x31), /**< Relationship Discovery Response event. \n See @ref ble_gattc_evt_rel_disc_rsp_t. */
BLE_GATTC_EVT_CHAR_DISC_RSP = 50 (0x32), /**< Characteristic Discovery Response event. \n See @ref ble_gattc_evt_char_disc_rsp_t. */
BLE_GATTC_EVT_DESC_DISC_RSP = 51 (0x33), /**< Descriptor Discovery Response event. \n See @ref ble_gattc_evt_desc_disc_rsp_t. */
BLE_GATTC_EVT_ATTR_INFO_DISC_RSP = 52 (0x34), /**< Attribute Information Response event. \n See @ref ble_gattc_evt_attr_info_disc_rsp_t. */
BLE_GATTC_EVT_CHAR_VAL_BY_UUID_READ_RSP = 53 (0x35), /**< Read By UUID Response event. \n See @ref ble_gattc_evt_char_val_by_uuid_read_rsp_t. */
BLE_GATTC_EVT_READ_RSP = 54 (0x36), /**< Read Response event. \n See @ref ble_gattc_evt_read_rsp_t. */
BLE_GATTC_EVT_CHAR_VALS_READ_RSP = 55 (0x37), /**< Read multiple Response event. \n See @ref ble_gattc_evt_char_vals_read_rsp_t. */
BLE_GATTC_EVT_WRITE_RSP = 56 (0x38), /**< Write Response event. \n See @ref ble_gattc_evt_write_rsp_t. */
BLE_GATTC_EVT_HVX = 57 (0x39), /**< Handle Value Notification or Indication event. \n Confirm indication with @ref sd_ble_gattc_hv_confirm. \n See @ref ble_gattc_evt_hvx_t. */
BLE_GATTC_EVT_EXCHANGE_MTU_RSP = 58 (0x3a), /**< Exchange MTU Response event. \n See @ref ble_gattc_evt_exchange_mtu_rsp_t. */
BLE_GATTC_EVT_TIMEOUT = 59 (0x3b), /**< Timeout event. \n See @ref ble_gattc_evt_timeout_t. */
BLE_GATTC_EVT_WRITE_CMD_TX_COMPLETE = 60 (0x3c), /**< Write without Response transmission complete. \n See @ref ble_gattc_evt_write_cmd_tx_complete_t. */
enum BLE_GATTS_EVTS
BLE_GATTS_EVT_WRITE = 80 (0x50), /**< Write operation performed. \n See @ref ble_gatts_evt_write_t. */
BLE_GATTS_EVT_RW_AUTHORIZE_REQUEST = 81 (0x51), /**< Read/Write Authorization request. \n Reply with @ref sd_ble_gatts_rw_authorize_reply. \n See @ref ble_gatts_evt_rw_authorize_request_t. */
BLE_GATTS_EVT_SYS_ATTR_MISSING = 82 (0x52), /**< A persistent system attribute access is pending. \n Respond with @ref sd_ble_gatts_sys_attr_set. \n See @ref ble_gatts_evt_sys_attr_missing_t. */
BLE_GATTS_EVT_HVC = 83 (0x53), /**< Handle Value Confirmation. \n See @ref ble_gatts_evt_hvc_t. */
BLE_GATTS_EVT_SC_CONFIRM = 84 (0x54), /**< Service Changed Confirmation. \n No additional event structure applies. */
BLE_GATTS_EVT_EXCHANGE_MTU_REQUEST = 85 (0x55), /**< Exchange MTU Request. \n Reply with @ref sd_ble_gatts_exchange_mtu_reply. \n See @ref ble_gatts_evt_exchange_mtu_request_t. */
BLE_GATTS_EVT_TIMEOUT = 86 (0x56), /**< Peer failed to respond to an ATT request in time. \n See @ref ble_gatts_evt_timeout_t. */
BLE_GATTS_EVT_HVN_TX_COMPLETE = 87 (0x57), /**< Handle Value Notification transmission complete. \n See @ref ble_gatts_evt_hvn_tx_complete_t. */
enum BLE_L2CAP_EVTS
BLE_L2CAP_EVT_CH_SETUP_REQUEST = 112 (0x70), /**< L2CAP Channel Setup Request event. \n Reply with @ref sd_ble_l2cap_ch_setup. \n See @ref ble_l2cap_evt_ch_setup_request_t. */
BLE_L2CAP_EVT_CH_SETUP_REFUSED = 113 (0x71), /**< L2CAP Channel Setup Refused event. \n See @ref ble_l2cap_evt_ch_setup_refused_t. */
BLE_L2CAP_EVT_CH_SETUP = 114 (0x72), /**< L2CAP Channel Setup Completed event. \n See @ref ble_l2cap_evt_ch_setup_t. */
BLE_L2CAP_EVT_CH_RELEASED = 115 (0x73), /**< L2CAP Channel Released event. \n No additional event structure applies. */
BLE_L2CAP_EVT_CH_SDU_BUF_RELEASED = 116 (0x74), /**< L2CAP Channel SDU data buffer released event. \n See @ref ble_l2cap_evt_ch_sdu_buf_released_t. */
BLE_L2CAP_EVT_CH_CREDIT = 117 (0x75), /**< L2CAP Channel Credit received. \n See @ref ble_l2cap_evt_ch_credit_t. */
BLE_L2CAP_EVT_CH_RX = 118 (0x76), /**< L2CAP Channel SDU received. \n See @ref ble_l2cap_evt_ch_rx_t. */
BLE_L2CAP_EVT_CH_TX = 119 (0x77), /**< L2CAP Channel SDU transmitted. \n See @ref ble_l2cap_evt_ch_tx_t. */
