nRF UART app Send
FormerMember
FormerMember
In the nRF UART v2.0 App, the app have the "send" command. And I can send the data to my nRF52 DK, and it print what I'm sending on the Serial monitor.
However, in the ble_app_uart example code, I don't see where this function of code is locate, Does anyone know where in the code this function is called which when we "send" the data from phone to nRF52 and print it out on monitor?
Thanks.
  • I think what you are looking for is the callback function nus_data_handler() in main.c
    The handler is passed to the uart service during initialisation, and the on_write() function in the uart service calls the function pointer (which points to the callback function in main)
    If you are not seeing any output on your hardware (UART) pins, then you don't have the TX and RX pins configured correctly for the board you are using.
  • FormerMember
    0 FormerMember in reply to Roger Clark
    Solved this problem myself. Here is the solution, hope can help others.
    static void nus_data_handler(ble_nus_t * p_nus, uint8_t * p_data, uint16_t length)
    	memset(&send_value,0x00,length);
        for (uint32_t i = 0; i < length; i++)
            while (app_uart_put(p_data[i]) != NRF_SUCCESS);
    // Read what the "data request" is send from the smart phone. Refer to "spi_event_handler()"
    	    send_value = send_value * 10 + (p_data[i] - '0');
        while (app_uart_put('\r') != NRF_SUCCESS);
        while (app_uart_put('\n') != NRF_SUCCESS);
    // print what send_value is
    		printf("send_value: %d\n",send_value);
    by @faweiz
  • FormerMember
    by @faweiz
