How to add device_manager in existing ble_app_uart code?
Hello, I am using sdk 11 and I am refering to code ble_app_uart. I am using nrf51 and I want to add passkey to this code. So do this I added
   // Add static pin:
uint8_t passkey[] = STATIC_PASSKEY;
ble_opt.gap_opt.passkey.p_passkey = passkey;
err_code =  sd_ble_opt_set(BLE_GAP_OPT_PASSKEY, &ble_opt);
Now I want to add
static void device_manager_init(void) { uint32_t err_code; dm_init_param_t init_data; dm_application_param_t register_param;
// Initialize persistent storage module.
err_code = pstorage_init();
// Clear all bonded centrals if the Bonds Delete button is pushed.
init_data.clear_persistent_data = 0;// (nrf_gpio_pin_read(BOND_DELETE_ALL_BUTTON_ID) == 0);
err_code = dm_init(&init_data);
memset(&register_param.sec_param, 0, sizeof(ble_gap_sec_params_t));
register_param.sec_param.timeout      = SEC_PARAM_TIMEOUT;
register_param.sec_param.bond         = SEC_PARAM_BOND;
register_param.sec_param.oob          = SEC_PARAM_OOB;
register_param.sec_param.min_key_size = SEC_PARAM_MIN_KEY_SIZE;
register_param.sec_param.max_key_size = SEC_PARAM_MAX_KEY_SIZE;
register_param.evt_handler            = device_manager_evt_handler;
register_param.service_type           = DM_PROTOCOL_CNTXT_GATT_SRVR_ID;
// Using static pin:
register_param.sec_param.mitm    = SEC_PARAM_MITM;
register_param.sec_param.io_caps = SEC_PARAM_IO_CAPABILITIES;
err_code = dm_register(&m_app_handle, &register_param);
So I am trying to add device_manager files from components. When I compiled I am getting error like ............\components\ble\device_manager\device_manager.h(72): error: #5: cannot open source input file "device_manager_cnfg.h": No such file or directory
My new file is ble_app_main.txt
Thanks
    Make sure that you have added the relevant files to the Keil project. This is done by right clicking on a project folder in the project window, and clicking on "Add existing files to Group". You also need to include the path for the files added; Options for Target->C/C++->Include Paths. In SDK 11 the device_manager_cnfg.h should be placed in the project config folder: SDK_FOLDER\examples\ble_peripheral\ble_app_uart\config. Take a look at e.g. the ble_app_hrs project to see how the config file is configured.
  • Note: If you are starting from stretch on this, I would recommend to download and use SDK 12.2 instead. SDK 12 uses the peer manager instead of the device manager. The functionality is the same, but there are several major improvements with the peer manger. See here for more information.
  • Hello Sigurd, I am following your suggestions and I am referring the code ble_app_hrs and ble_app_gls. I am editing the code ble_app_hrs. Now I want that my app should prompt the static passkey entry before connection. To do this I have made changes by referring ble_app_gls. I am attaching my txt file above in question. Thanks, Shailav
