nrf51 gcc gnu flashing dfu_bootloader, softdevice s130 and application
Hi
I don't understand how to correctly flash all three parts so that the app runs on boot.
At the moment if I flash them all the nrf51 (51822) boots to the dfu bootloader.
If I use dfu then to load the app. The app will then run ok
If I flash just the app and softdevice the app boots ok.
I've noticed quite a few questions like this on the forum - but none seem to work
If I do flash like this
  1. s130_nrf51_2.0.0_softdevice.hex
  2. bootloader.hex
  3. app.hex
  4. app_valid_setting_apply.hex
Then the app runs on boot - the dfu will start but the dfu app download fails
Any ideas?
  • There are 2 ways. Use Nordic mergehex with nrfjprog + jlink or use IDAPnRFProg + IDAP-Link. With IDAPnRFProg, you supply the 3 hex files in order (SD, App, DFU) it will take care of the app valid thing. No mergehex needed.
  • The problem was partly cause by me - I was using a raspberry pi to program the target - and also as BLE central listening to target advertising for test purposes. The rpi was physically very close to the target (1") and the dfu BLE central was 1 meter away. This setup seems to cause dfu <-> target comms issues.
    The solution to the initial programming issue is to use app_valid_setting_apply.hex but I don't understand what this actually does - anyway the following (openocd) sequence successfully programs the target.
    Program - soft device - add verify to test
    program s130_nrf51_2.0.0_softdevice.hex
    program - bootloader
    program dfu_test_bootloader_b_s130.hex
    Program - application
    program app.hex
    program app_valid_setting_apply.hex
