FDS: Saving my records
NRF52 DK on SDK 12.2 (using armGCC)
I have the FDS example from GITHUB working - it shows it is writing and reading the example data (0xDEADBEEF and 0xBAADF00D) fine. I want to save my own data as a record instead of the data in the example and I need assistance. Below are the variables that I need to save so I can recover them after a power outage or reboot.
uint8_t		currentSetting;
int16_t		photocellThreshold;
uint16_t	pwmValue;
bool		powerState;
uint32_t	remoteMode1;
uint32_t	remoteMode2;
uint32_t	remoteMode3;
I am not sure if I should have a separate record for each variable or if I should write all as 1 "chunk" of data. Which is better?
My problem is how do I save those different data types into FDS?
How do I recover the settings after reboot?
Also, If the user changes the setting or PWM value for instace, I will use a timer and after 20 seconds of no setting changes, I will update the data to FDS. How can I update that changed information back into FDS?
Can someone assist me? I appreciate any help!
Thanks, Bryan
  • Bryan
    You don't need to typedef the struct (as you only have one instance of it)
    So you can just do
    struct
        uint16_t    pwmValue;
        bool        powerState;
    } myData;
    main()
        	myData.currentSetting=12;// assign some initial value
    I've not used the FDS, but you should just need to do something like
    record_chunk.p_data = &myData;
    record_chunk.length_words = sizeof(myData)/4; // NOTE. I DONT KNOW WHAT SIZE IS A "WORD"
    Please check if a word is 4 bytes, but it appears to be as int32 (4 bytes) uses length_words = 1 infocenter.nordicsemi.com/index.jsp
  • Bryan
    So you can just do
    struct
        uint16_t    pwmValue;
        bool        powerState;
    } myData;
    main()
