I2C problem Zephyr OS sensor example
I'm trying out the Zephyr os for the NRF51.
When I try the basic BLE example they work fine!
However when I try the sensor example which uses the i2c it falls over with the following error:
dev 0x00000000 name ***** HARD FAULT ***** Executing thread ID (thread): 0x20001310 Faulting instruction address: 0x00000868 Fatal fault in ISR! Spinning...
Is the i2c on the nrf51 setup by the nrf51 sdk?
When configuring the i2c what should the following configs be set to:
CONFIG_I2C_0_NAME=? CONFIG_I2C_0_DEFAULT_CFG=? CONFIG_I2C_0_IRQ_PRI=?
BR Paul Grant
