My code hit weak handler when I try to modify the examples/peripheral/saadc to run with softdevice s140 on nrf82840 PDK. All I did was adding a BLE Stack initialization before calling saadc_init, saadc_sampling_event_init and saadc_sampling_event_enable. With DEBUG enabled it looks like the code is failing at nrf_drv_timer_init but not information is given through log utility.
Here is the ble_stack_init:
uint32_t err_code;
nrf_clock_lf_cfg_t clock_lf_cfg = NRF_CLOCK_LFCLKSRC;
// Initialize the SoftDevice handler module.
SOFTDEVICE_HANDLER_INIT(&clock_lf_cfg, NULL);
ble_enable_params_t ble_enable_params;
err_code = softdevice_enable_get_default_config(NRF_BLE_CENTRAL_LINK_COUNT,
NRF_BLE_PERIPHERAL_LINK_COUNT,
&ble_enable_params);
//Check the ram settings against the used number of links
CHECK_RAM_START_ADDR(NRF_BLE_CENTRAL_LINK_COUNT, NRF_BLE_PERIPHERAL_LINK_COUNT);
// Enable BLE stack.
ble_enable_params.gatt_enable_params.att_mtu = NRF_BLE_GATT_MAX_MTU_SIZE;
err_code = softdevice_enable(&ble_enable_params);
// Register with the SoftDevice handler module for BLE events.
err_code = softdevice_ble_evt_handler_set(ble_evt_dispatch);
// Register with the SoftDevice handler module for System events.
err_code = softdevice_sys_evt_handler_set(sys_evt_dispatch);
and the main function:
ret_code_t err_code;
err_code = NRF_LOG_INIT(NULL);
NRF_LOG_INFO("Initializing BLE stack\r\n");
ble_stack_init();
saadc_init();
saadc_sampling_event_init();
while (1)
sd_app_evt_wait();
It's most likely something related to interruption priorities or resources taken by SD. I use SDK 12.
EDIT: I also should mention that I like the approach with PPI (Timer -> SAADC), so that timer triggers adc sampling task and in the result I have a continuous sampling with some specified interval (miliseconds).
