Is Direct Test Mode for Bluetooth 5 released?
If not, when are you going to schedule it?
Thanks
Thanks
Q1: Is Direct Test Mode for Bluetooth 5 released?
A1: No.
Q2: If not, when are you going to schedule it
A2: We are awaiting support for BLE 5 in the 3rd party test-labs that does certifications. This is scheduled to arrive in February/March, and the DTM will then be released in maybe April/May. Since the timeline is depending on a 3rd party company, schedules are not set in stone and may be adjusted.
EDIT: SDK 14.0 is now released with Direct Test Mode support for Bluetooth 5.
SDK 14 is now released with Direct Test Mode support for Bluetooth 5.
We have to do production testing of our product. For mass production testing to do faster, can you specify me which of production programming among PEmicro, segger production programmers, nrfjprog can I use for mass production of modules.
Sridhar
Hi Sridhar,
For production programming we have a infocenter page here you should take a look at. We also have a more detailed whitepaper here.
Summarized:
You have two options when programming for production:
In-system programming (ISP): ISP is used when programming is needed after the assembly of the final PCB. Here we recommend using a SEGGER Production Programmer.
Socket programming: Socket programming is used when the SoC is pre-programmed before it's mounted on a PCB. Here we recommend using a production programmer from either Elnec or Hi-Lo systems.
