Timeslot extension
Hello all,
After several tests about extending Timeslot, I have some questions.
  1. I found out that the Timeslot will keep extending automatically after a successful extension, right?
  2. If I am right about the first question, then about the extension length, in my code, extend.length_us = 200, and the "callback_action" will be set to "NRF_RADIO_SIGNAL_CALLBACK_ACTION_END" if the total length above 120,000,000 us, so that the Timeslot will end rather than exceed the 128s limit and extend failed.
    I used the "NRF_LOG_INFO" printed the result:
    :INFO:NRF_EVT_RADIO_SESSION_IDLE
    :INFO:NRF_EVT_RADIO_SESSION_CLOSED
    :INFO: extend_success_count = 600000
    :INFO: extend_fail_count = 0
     case NRF_RADIO_CALLBACK_SIGNAL_TYPE_EXTEND_SUCCEEDED:
         if(total_timeslot_length >= 120000000)
             signal_callback_return_param.callback_action = NRF_RADIO_SIGNAL_CALLBACK_ACTION_END;
         }else
         total_timeslot_length += 200;
         extend_success_count++;
     case NRF_RADIO_CALLBACK_SIGNAL_TYPE_EXTEND_FAILED:
         fail_count++;
Also in Timeslot event handler:
    case NRF_EVT_RADIO_SESSION_IDLE:
        sd_radio_session_close();
        NRF_LOG_INFO("NRF_EVT_RADIO_SESSION_IDLE\r\n");
    case NRF_EVT_RADIO_SESSION_CLOSED:
        NRF_LOG_INFO("NRF_EVT_RADIO_SESSION_CLOSED\r\n");
        NRF_LOG_INFO(" extend_success_count            = %d\r\n", extend_success_count);
        NRF_LOG_INFO(" extend_fail_count               = %d\r\n", fail_count);
But the problem is: the real time about the extension was far less that 120 seconds, only few seconds and as I increase the "extend_length", the real time get even shorter, so where is the problem?
Many thanks!
  • You check if you get the callback signal NRF_RADIO_CALLBACK_SIGNAL_TYPE_EXTEND_FAILED or NRF_RADIO_CALLBACK_SIGNAL_TYPE_EXTEND_SUCCEEDED? See the radio timeslot extension example in the SoftDevice specification.
    If you try to extend the the timeslot and this will conflict with already scheduled SoftDevice activities of equal or higher priority you will get the extend failed signal. See here and here for more info on the scheduler and the SoftDevice priorities.
  • Thanks, but I don't think I got any extension failed signal, because I kept counting all the time, if there is any failure, the "fail_count" shouldn't be 0.
  • And fail_count is declared as volatile? You should put a breakpoint in the case and go into debug mode to check if you get the extend failed signal.
    How many extends do you get?
    Do you get the problem if you are not in a connection and not advertising or scanning (only initialized the SoftDevice)?
  • fail_count was declared as static, I changed to volatile, the result was the same. I am not familiar with debug, but I set a break point at "case NRF_RADIO_CALLBACK_SIGNAL_TYPE_EXTEND_FAILED", the application did not run to that point. You mean the reason why the real extension time is short should be extension failure? So if assume nothing goes wrong, the real extend time should be 120s? I did only initialized the SoftDevice(no connection and advertising) all the time.
  • The NRF_RADIO_CALLBACK_SIGNAL_TYPE_EXTEND_SUCCEEDED signal or the NRF_RADIO_CALLBACK_SIGNAL_TYPE_EXTEND_FAILED signal will come right after you give the action NRF_RADIO_SIGNAL_CALLBACK_ACTION_EXTEND.
    The way your code works now is that you extend the timeslot until you have successfully extended to 120 seconds. This will happen in the first milliseconds of the timeslot as you call the extend signal back to back. When you have extended the timeslot to 120 seconds you immediately ends it, long before the 120 seconds have elapsed.
    What you should do is to configure the TIMER0 interrupt to fire right before the timeslot is going to expire. I have put together some code that demonstrates this, it is based on the timeslot tutorial:
    timeslot.c
    The timeslot will end after 120 seconds minus the margin with 600 000 successful extends.
