sd_softdevice_enable() crashes on nRF52832 when debugging
Hi Everybody
When I run my code with the debugger, it always crashes when executing sd_softdevice_enable(). Even if there is no breakpoint activated. However, when I run the code without the debugger, it works fine.
I am using the PCA10040 dev board together with VisaulGDB for VisualStudio. The SDK is 12.2.0 togehter with the S132_nrf52_3.0.0 softdevice.
Does anybody have any idea?
Thanks
  • Hello Fabi,
    I believe I'm encountering the same error and I think I know why. Note: I'm using the S140 softdevice on the nRF52840, but I believe it's the same issue.
    When you are debugging with the J-Link, you load your app past the SoftDevice and the debugger will typically start you in the Reset_Handler of your app. The key here is that debugging avoids running the Reset_Handler in the SoftDevice, which appears to setup a bunch of stuff that must be done before calling sd_softdevice_enable.
    On the flip-side, a true reset, launches using the Reset_Handler as specified in the SoftDevice, which then eventually runs the Reset_Handler of your app. As it should be.
    So, I think you can possibly specify the initial actions of your debugger and instruct it to do a hardware reset and run from there. I'm currently stuck on this part--I'm using Segger's Ozone and can't seem to find a way to specify the Reset Strategy. However, I have a pretty easy workaround--use the reset button in Ozone and then run from there--that seems to do the trick--I just wish I could get it to reset on first debug.
    I hope that helps! (And I hope this is what's really going on..)
  • @facotl: So using Ozone, resetting and run does not work for you?
