After sd_ble_gap_disconnect() no BLE_GAP_EVT_DISCONNECTED is fired
Hello
In case a connection is disconnected locally by calling sd_ble_gap_disconnect(), no BLE_GAP_EVT_DISCONNECTED is fired even though the sd_ble_gap_disconnect() function returned with NRF_SUCCESS.
I am using SDK 12.2.0 on a PCA 10040 board,
Thanks
  • What example is this? Is the SoftDevice handler set?
    err_code = softdevice_ble_evt_handler_set(ble_evt_dispatch);
  • I do the same initialisation as in the examples:
        uint32_t err_code;
        nrf_clock_lf_cfg_t clock_lf_cfg = NRF_CLOCK_LFCLKSRC;
        // Initialize the SoftDevice handler module.
        SOFTDEVICE_HANDLER_APPSH_INIT(&clock_lf_cfg, true);
        ble_enable_params_t ble_enable_params;
        err_code = softdevice_enable_get_default_config(CENTRAL_LINK_COUNT,
                                                        PERIPHERAL_LINK_COUNT,
                                                        &ble_enable_params);
        // Check the ram settings against the used number of links
        CHECK_RAM_START_ADDR(CENTRAL_LINK_COUNT, PERIPHERAL_LINK_COUNT);
        // Enable BLE stack.
    #if (NRF_SD_BLE_API_VERSION == 3)
        ble_enable_params.gatt_enable_params.att_mtu = NRF_BLE_MAX_MTU_SIZE;
        err_code = softdevice_enable(&ble_enable_params);
        // Register with the SoftDevice handler module for BLE events.
        err_code = softdevice_sys_evt_handler_set(sys_evt_dispatch);
  • How are you debugging this? With NRF_LOG ? Debug-session with break-point? What does the chip do after the disconnect?
  • Yes by logging output. The chips is not doing anything, no further events are dispatched. my application just waits for the BLE_GAP_EVT_DISCONNECTED event.
  • Does the chip go back to advertising after you disconnect? Are the other events logged? such as BLE_GAP_EVT_CONNECTED ?
