sd_ble_gatts_value_set returns NRF_ERROR_NOT_FOUND
I am using the sd_ble_getts_value_set() function two times in a row on two different characteristics. Both characteristics are part of the same service. At the moment of usage, there is an open ble connection. My function call looks like:
err_code = sd_ble_gatts_value_set(BLE_CONN_HANDLE_INVALID, m_device.chstate_handle.value_handle, &gatts_value);
On both characteristics, the function returns NRF_ERROR_NOT_FOUND. Surprisingly, it seems to work, so the characteristics I want to update, are updated with the new value.
Can you give me any hint, where to have a look on?
Regards, BTprogrammer
  • Ok, I think I got it. It is not possible to update a value with sd_ble_gatts_value_set, when the SD is in central role. But it is enough to change the variable. When switching back to peripheral role, the function services_init() will be called. This will initialize the characteristic with the new value. This is why it works. That is what I can see after some investigations. Hope thats right. ;-)
