nrf51822 bonding/whitelist creation
I am trying to scan and connect to a Polar H7 HR belt (which I can do), with m_scan_mode = BLE_NO_SCAN. Once this happens, I understand they are supposed to bond, and at that point, the H7 belt details will be saved to the whitelist. Then after doing that I can scan with m_scan_mode = BLE_WHITELIST_SCAN and be assured I am connecting to the correct HR belt.
I can connect to the belt just fine, but after restarting, my whitelist is always blank. I also put a breakpoint on the line: DM_LOG("[DM]:[CI 0x%02X]:[DI 0x%02X]: Bonded!\r\n", in my app, which is based on ble_app_hrs_c. This breakpoint never gets hit.
I've spent all day trying to get the belt added to whitelist, pulling my hair out :-( Does anyone have any ideas?
Code bits look like below. When I do my initial scan, PairingScan is set to 1, and when I am just trying to connect to the supposebly whitelisted belt, PairingScan is set to 0.
static void device_manager_init(void){
dm_application_param_t param;
dm_init_param_t        init_param;
err_code = pstorage_init();
	if(PairingScan == 1)		//initial scan to pair a new belt
		init_param.clear_persistent_data = true;
		m_scan_mode =  BLE_NO_SCAN;
		//printf("Clearing whitelist, open scanning\n\r");
		m_scan_mode =  BLE_WHITELIST_SCAN;
		//printf("whitelist scan started\n\r");
err_code = dm_init(&init_param);
memset(&param.sec_param, 0, sizeof (ble_gap_sec_params_t));
// Event handler to be registered with the module.
param.evt_handler            = device_manager_event_handler;
// Service or protocol context for device manager to load, store and apply on behalf of application.
// Here set to client as application is a GATT client.
param.service_type           = DM_PROTOCOL_CNTXT_GATT_CLI_ID;
// Secuirty parameters to be used for security procedures.
param.sec_param.bond         = SEC_PARAM_BOND;
param.sec_param.mitm         = SEC_PARAM_MITM;
param.sec_param.io_caps      = SEC_PARAM_IO_CAPABILITIES;
param.sec_param.oob          = SEC_PARAM_OOB;
param.sec_param.min_key_size = SEC_PARAM_MIN_KEY_SIZE;
param.sec_param.max_key_size = SEC_PARAM_MAX_KEY_SIZE;
param.sec_param.kdist_periph.enc = 1;
param.sec_param.kdist_periph.id  = 1;
err_code = dm_register(&m_dm_app_id, &param);
and then, my scan_start() function looks like this below. I always end up hitting the 'doscan = false' line as there is nothing in my whitelist.
static void scan_start(void)
{ bool doscan = true; ble_gap_whitelist_t whitelist; ble_gap_addr_t * p_whitelist_addr[BLE_GAP_WHITELIST_ADDR_MAX_COUNT]; ble_gap_irk_t * p_whitelist_irk[BLE_GAP_WHITELIST_IRK_MAX_COUNT]; uint32_t err_code; uint32_t count;
// Verify if there is any flash access pending, if yes delay starting scanning until
// it's complete.
err_code = pstorage_access_status_get(&count);
if (count != 0)
    m_memory_access_in_progress = true;
    return;
// Initialize whitelist parameters.
whitelist.addr_count = BLE_GAP_WHITELIST_ADDR_MAX_COUNT;
whitelist.irk_count  = 0;
whitelist.pp_addrs   = p_whitelist_addr;
whitelist.pp_irks    = p_whitelist_irk;
// Request creating of whitelist.
err_code = dm_whitelist_create(&m_dm_app_id,&whitelist); APP_ERROR_CHECK(err_code);
	if (m_scan_mode != BLE_WHITELIST_SCAN)
    // No devices in whitelist, hence non selective performed.
    m_scan_param.active       = 0;            // Active scanning set.
    m_scan_param.selective    = 0;            // Selective scanning not set.
    m_scan_param.interval     = SCAN_INTERVAL;// Scan interval.
    m_scan_param.window       = SCAN_WINDOW;  // Scan window.
    m_scan_param.p_whitelist  = NULL;         // No whitelist provided.
    m_scan_param.timeout      = 0x0000;       // No timeout.
		if ((whitelist.addr_count == 0) && (whitelist.irk_count == 0))
			//we don't have a whitelist yet, don't scan at all.
			doscan = false;
			// Selective scanning based on whitelist
			m_scan_param.selective    = 1;            // Selective scanning not set.
			m_scan_param.p_whitelist  = &whitelist;   // Provide whitelist.
			m_scan_param.timeout      = 0x0000;       // no timeout.
			// Set whitelist scanning state.
	if(doscan == true)
		err_code = sd_ble_gap_scan_start(&m_scan_param);
  • Are you sure you are actually bonded with the HR belt? Do you get a BLE_GAP_EVT_AUTH_STATUS event, where the bonded field = 1?
  • Hi, No it doesn't appear to be bonding, I don't hit a breakpoint in the BLE_GAP_EVT_AUTH_STATUS case in dm_ble_evt_handler.. How do I initiate bonding? from what I can see bonding is supposed to be carried out. I do hit a breakpoint in the bit below:
    case BLE_HRS_C_EVT_DISCOVERY_COMPLETE:
            // Initiate bonding.
            err_code = dm_security_setup_req(&m_dm_device_handle);
    My debug printf's look like this when doing the inital pairing: *edit - I can't paste the debug printf's in this stupid comment box, only the first line shows up. I'll try paste it in as an answer to my question, don't know what else to try *
  • this is what I get out of the debug output, no mention of bonding:
    [APPL]: af0[APPL]: 180d[APPL]: >> DM_EVT_CONNECTION[APPL]:[88 B7 DB D0 22 00]: onnection Established[APPL]: << DM_EVT_CONNECTION[APPL]: Battery Service discovered.[APPL]: Reading battery level.[APPL]: Enabling Battery Level Notification.[APPL]: >> M_EVT_SECURITY_SETUP_COMPLETE[APPL]: << DM_EVT_SECURITY_SETUP_COMPLETE[APPL]: HR easurement received 0û[APPL]: HR Measurement received 0[APPL]: Battery Level Read as 100 %[APPL]: HR Measurement received 0[APPL]: HR Measurement received 0
  • Ok, I've found something strange. I use a Laird BL620 module to run my app on. On one of my units, the HR belt gets bonded to when pairing it. On the other, it pairs and connects but never goes on to do the bonding. The only difference seems to be in the part number of the Laird modules - BL620-SA-01 for the one that bonds, BL620-SA-02 for the module that doesn't bond. Very strange..
  • But you are able to do whitelist scanning with the one that is bonded, right? The whitelist is created using dm_whitelist_create, which get's the device address'es and IRK's from the bond table. So it you haven't bonded nothing will be there to create the whitelist.
