nrf51822 bonding/whitelist creation
I am trying to scan and connect to a Polar H7 HR belt (which I can do), with m_scan_mode = BLE_NO_SCAN. Once this happens, I understand they are supposed to bond, and at that point, the H7 belt details will be saved to the whitelist. Then after doing that I can scan with m_scan_mode = BLE_WHITELIST_SCAN and be assured I am connecting to the correct HR belt.
I can connect to the belt just fine, but after restarting, my whitelist is always blank. I also put a breakpoint on the line: DM_LOG("[DM]:[CI 0x%02X]:[DI 0x%02X]: Bonded!\r\n", in my app, which is based on ble_app_hrs_c. This breakpoint never gets hit.
I've spent all day trying to get the belt added to whitelist, pulling my hair out :-( Does anyone have any ideas?
Code bits look like below. When I do my initial scan, PairingScan is set to 1, and when I am just trying to connect to the supposebly whitelisted belt, PairingScan is set to 0.
static void device_manager_init(void){
dm_application_param_t param;
dm_init_param_t        init_param;
err_code = pstorage_init();
	if(PairingScan == 1)		//initial scan to pair a new belt
		init_param.clear_persistent_data = true;
		m_scan_mode =  BLE_NO_SCAN;
		//printf("Clearing whitelist, open scanning\n\r");
		m_scan_mode =  BLE_WHITELIST_SCAN;
		//printf("whitelist scan started\n\r");
err_code = dm_init(&init_param);
memset(&param.sec_param, 0, sizeof (ble_gap_sec_params_t));
// Event handler to be registered with the module.
param.evt_handler            = device_manager_event_handler;
// Service or protocol context for device manager to load, store and apply on behalf of application.
// Here set to client as application is a GATT client.
param.service_type           = DM_PROTOCOL_CNTXT_GATT_CLI_ID;
// Secuirty parameters to be used for security procedures.
param.sec_param.bond         = SEC_PARAM_BOND;
param.sec_param.mitm         = SEC_PARAM_MITM;
param.sec_param.io_caps      = SEC_PARAM_IO_CAPABILITIES;
param.sec_param.oob          = SEC_PARAM_OOB;
param.sec_param.min_key_size = SEC_PARAM_MIN_KEY_SIZE;
param.sec_param.max_key_size = SEC_PARAM_MAX_KEY_SIZE;
param.sec_param.kdist_periph.enc = 1;
param.sec_param.kdist_periph.id  = 1;
err_code = dm_register(&m_dm_app_id, &param);
and then, my scan_start() function looks like this below. I always end up hitting the 'doscan = false' line as there is nothing in my whitelist.
static void scan_start(void)
{ bool doscan = true; ble_gap_whitelist_t whitelist; ble_gap_addr_t * p_whitelist_addr[BLE_GAP_WHITELIST_ADDR_MAX_COUNT]; ble_gap_irk_t * p_whitelist_irk[BLE_GAP_WHITELIST_IRK_MAX_COUNT]; uint32_t err_code; uint32_t count;
// Verify if there is any flash access pending, if yes delay starting scanning until
// it's complete.
err_code = pstorage_access_status_get(&count);
if (count != 0)
    m_memory_access_in_progress = true;
    return;
// Initialize whitelist parameters.
whitelist.addr_count = BLE_GAP_WHITELIST_ADDR_MAX_COUNT;
whitelist.irk_count  = 0;
whitelist.pp_addrs   = p_whitelist_addr;
whitelist.pp_irks    = p_whitelist_irk;
// Request creating of whitelist.
err_code = dm_whitelist_create(&m_dm_app_id,&whitelist); APP_ERROR_CHECK(err_code);
	if (m_scan_mode != BLE_WHITELIST_SCAN)
    // No devices in whitelist, hence non selective performed.
    m_scan_param.active       = 0;            // Active scanning set.
    m_scan_param.selective    = 0;            // Selective scanning not set.
    m_scan_param.interval     = SCAN_INTERVAL;// Scan interval.
    m_scan_param.window       = SCAN_WINDOW;  // Scan window.
    m_scan_param.p_whitelist  = NULL;         // No whitelist provided.
    m_scan_param.timeout      = 0x0000;       // No timeout.
		if ((whitelist.addr_count == 0) && (whitelist.irk_count == 0))
			//we don't have a whitelist yet, don't scan at all.
			doscan = false;
			// Selective scanning based on whitelist
			m_scan_param.selective    = 1;            // Selective scanning not set.
			m_scan_param.p_whitelist  = &whitelist;   // Provide whitelist.
			m_scan_param.timeout      = 0x0000;       // no timeout.
			// Set whitelist scanning state.
	if(doscan == true)
		err_code = sd_ble_gap_scan_start(&m_scan_param);
