How do I get data from a scan response packet using master emulator?
I do know about
BtScanParameters scanParams = new BtScanParameters();
scanParams.ScanType = BtScanType.ActiveScanning;
But this doesn't seem to be enough.
I am working off of the example code from the "HealthThermoDemo" I want to access the ManufacturerSpecificData from a scan response packet so that I can use that data to add to the list of available devices in the OnDeviceDiscovered function.
What do I need to do?
(Note: the ManufacturerSpecificData is only in scan response packet not in both places so I don't have to worry about this)
Edit:
This is my OnDeviceDiscovered() function:
void OnDeviceDiscovered(object sender, ValueEventArgs<BtDevice> e)
this.BeginInvoke((MethodInvoker)delegate()
dgvDeviceDiscovery.Enabled = true;
dgvDeviceDiscovery.Visible = true;
BtDevice dev = e.Value;
string deviceName = "";
IDictionary<DeviceInfoType, string> deviceInfo = dev.DeviceInfo;
if (deviceInfo.ContainsKey(DeviceInfoType.CompleteLocalName))
deviceName = deviceInfo[DeviceInfoType.CompleteLocalName];
else if (deviceInfo.ContainsKey(DeviceInfoType.ShortenedLocalName))
deviceName = deviceInfo[DeviceInfoType.ShortenedLocalName];
return;
string manufData = "";
if (deviceInfo.ContainsKey(DeviceInfoType.ManufacturerSpecificData))
manufData = deviceInfo[DeviceInfoType.ManufacturerSpecificData];
string key = deviceName + " (adr: " + dev.DeviceAddress + ")" + " (MSD: " + manufData + ")";
discoveredDevicesList[key] = dev;
dgvDeviceDiscovery.RowCount = discoveredDevicesList.Count;
