Turn off UART on nrf52832
I noticed that having the UART enabled on my application in a NRF52 (SD132, SDK 11.0.0) takes a lot of current consumption. If I completely disable any UART support on my application the current consumption drops dramatically. I can't do that, but considering my device will be 99% of the time idle, I need to disabled the UART before I put the processor to sleep.
I am using FreeRTOS so what I did is I enabled the ApplicationIdleHook and did as follows:
/* FreeRTOS application idle hook */
void vApplicationIdleHook(void) {
    // Disable UART transmission and reception
    bool uart_disabled = false;
    if (!nrf_drv_uart_tx_in_progress()) {
        NRF_UART0->TASKS_SUSPEND = 1;
        //NRF_UART0->ENABLE = 0;
        uart_disabled = true;
    __WFI();
    if (uart_disabled) {
        //NRF_UART0->ENABLE = 1;
        NRF_UART0->TASKS_STARTTX = 1;
        NRF_UART0->TASKS_STARTRX = 1;
That theoretically should suspend the UART but unfortunately it increases current consumption compared to simply doing __WFI() and leaving the UART as it is. Notice that if I enable the lines where I do NRF_UART0->ENABLE = 0 and NRF_UART0->ENABLE = 1 the UART simply stops working.
I wonder that is the right way to disable the UART when you go to sleep.
  • You are mixing up using UART driver and accessing registers directly. This will cause the unpredictable behavior you are seeing now. I recommend you to uninit UART and init again using the driver. Since you said that it will 99% in idle the overhead for uninit and init everytime it wakes up is negligible.
            nrf_drv_uart_uninit(uart_instance);
        __WFI();
            nrf_drv_uart_init(xxx);
    I think the reason that writing directly to ENABLE not working is because the pins are still configured to be connected to UART . Anyways, let the driver take care of this.
  • I couldn't replicate the problem with a minimal example but I finally found out the solution. On the project I work in we add a timestamp to any message we log through the UART. And we calculate that timestamp in seconds using floating point operations. The issue was related to the one in devzone.nordicsemi.com/.../, as I didn't clear the FPU interrupt flags.
