is there any Example to use the UART ? I need an monitor while the application is running, is the UART COM Port the right one for this?
Is there an example with the app_uart?
Best regards Nils
Best regards Nils
I need also help to send printf outputs via UART to a serial terminal.
I am also working on Eclipse + GCC environment and using Evaluation Kit and my BLE application uses S110_SoftDevice.
questions are:
Yalcin
I started with eclipse and gcc, but didn't get it to work fine. Now i am working with Keil, normaly it works fine.
But i need an monitor on the pc to talk with the device in the runtime, like you need it, right?
nils
there are a few UART examples in the SDK, depending on which hardware you are using (Evaluation Kit or Development Kit). If you are using the PCA10001 Evaluation board, take a look at nrf51822\Board\pca10001\uart_example. This example uses the com port interface, which is conveniently accessed via the USB. Albeit this example is quite simple..
As far as I know, app_uart is part of the HCI transport layer, which is used in the connectivity chip examples. This transport layer is quite complex and not something you would use as a monitoring tool for debugging.
