Editing LEDS_ON and LEDS_OFF
I am working on a project using a ble nano (nrf51822) using the Nordic SDK 8.1. In the examples I found a way to control the onboard led that uses the methods LEDS_ON and LEDS_OFF. I wanted to change my code to light up an external LED attached to a GPIO pin instead of the onboard LED. To do this I went into the header file for the board (custom_board.h) and changed the pin number from the onboard LED to an external LED. After doing this I was surprised to find out that LEDS_OFF turned the external LED on and LEDS_ON turned the external LED off. Now I'm wondering how I can fix this. My thoughts are I have 2 possible approaches: 1) Swap the LEDS_ON and LEDS_OFF functions by editing them. I can't figure out how I would do that though. How can I change these functions? Or 2) Create my own function that controls the LED attached to the GPIO pin and replace all instances of LEDS_ON and LEDS_OFF with it. How should I tackle this problem?
    The simplest solution would propably be to swap the definition of LEDS_ON and LEDS_OFF. They are defined in boards.h, which can be found in [SDK_ROOT]\examples\bsp\. Notice that changing this file will affect all other examples in the SDK, meaning you will have to change it back if you want to controll active low LEDs like the ones on the nRF51 DK with these functions again (to avoid getting inverted results).
    Jørgen
  • We are using 8.1 because we are building off an example that used 8.1. Is there an easy way to update to the newest SDK? I don't want to spend a lot of time updating it if I don't have to.... Also the LED_IS_ON would always return a non-zero long. I ended up fixing this by using the LED_INVERT function instead of using the LEDS_ON and LEDS_OFF methods.
