ble_radio_notification_evt_handler_t timeslot API and softdevice
I am using the timeslot API and softdevice to advertise two separate types of message. This works well. But I have also used ble_radio_notification_evt_handler_t in an attempt to change the payload of the softdevice advertisement.
Unfortunately through experimentation I have found that ble_radio_notification_evt_handler_t is called on any radio activity. There doesn't appear to be a context.
Any ideas how to run code before or after (just) the softdevice advertises?
I'm using S130 V11 nrf51
Many thanks in advance
John
  • Hi Kristin, Roger,
    I believe that timer actually might solve it if you set it to the middle of the adv. interval then jitter should oscillate a bit but in average you could run both adv. interval and timer in sync. Of course this isn't usable if you need 100% precision over long period of time (hours/days).
    Cheers Jan
  • On a first look it seems to me kind of overkill to fire timer for one-time period on each such event, I'd rather set infinite timer and sync it once with adv. interval (and then resync as needed - hourly or longer?). Again it works until you don't require 100% timer accuracy over long periods. In that case you would need to go with custom (or open source) stack and make this inherit feature of low layers...
