ble_radio_notification_evt_handler_t timeslot API and softdevice
I am using the timeslot API and softdevice to advertise two separate types of message. This works well. But I have also used ble_radio_notification_evt_handler_t in an attempt to change the payload of the softdevice advertisement.
Unfortunately through experimentation I have found that ble_radio_notification_evt_handler_t is called on any radio activity. There doesn't appear to be a context.
Any ideas how to run code before or after (just) the softdevice advertises?
I'm using S130 V11 nrf51
Many thanks in advance
John
  • Johnnofleek
    Yikes...
    I presumed the same as you, that the radio event related to when the radio was going to transmit, not all of the internals of what other stuff it was doing
    I wonder if there is a way to read some other register or part of the SD to determine what the event was caused by.
    But, If you get loads of interrupts, I guess, checking for what the type of radio notification, is going to wake the CPU up far too much, and not be a usable solution for low power application.
    I think Nordic need to clarify this, and how you are supposed to update data in between transmissions.
    BTW. I see that the event handler is passed a flag to say when the radio is inactive, so wonder how many interrupts per advertising period you get when that flag is false
  • On a first look it seems to me kind of overkill to fire timer for one-time period on each such event, I'd rather set infinite timer and sync it once with adv. interval (and then resync as needed - hourly or longer?). Again it works until you don't require 100% timer accuracy over long periods. In that case you would need to go with custom (or open source) stack and make this inherit feature of low layers...
