Disconnect from Peripheral and stop Advertising
Hello ,
I'm working on custom board, I'm trying to disconnect from the Central (Andriod app) when the battery is below certain level and stop re-advertising. Below is the piece of code i used:
/* Disconnect and then disable advertising */
if (m_conn_handle != BLE_CONN_HANDLE_INVALID) { sd_ble_gap_disconnect(m_conn_handle,BLE_HCI_REMOTE_USER_TERMINATED_CONNECTION); }
uint32_t err_code = sd_ble_gap_adv_stop();
I'm trying to disconnect and disable advertising but it doesn't work in some cases, I don't really know why.
I use SDK v11 with S132 v2.0.0 (nRF52)
    If you call sd_ble_gap_adv_stop() when you are not advertising, the function will return NRF_ERROR_INVALID_STATE. The APP_ERROR_CHECK() will therefore call the error handling function. Don't call the sd_ble_gap_adv_stop() when you are not advertising, or ignore the invalid state error message. The sd_ble_gap_disconnect() function will also return NRF_ERROR_INVALID_STATE if you try to call it when e.g. a disconnection is already in progress. Try this code instead, and see if it solves your issues:
    uint32_t err_code;
        err_code = sd_ble_gap_disconnect(m_conn_handle, BLE_HCI_REMOTE_USER_TERMINATED_CONNECTION);
    uint32_t err_code;
