BUG in nrf52_common.ld?
Using GCC 4.8.4, it seems to me, that the nrf52_common.ld shiped with the sdk version 12.2 contains a bug:
If an image is defined where the .text data fits into the flash, but where the .data initialization data would lead to an overflow of the flash, the linker does not complain about the overflow.
The reasons for this seems to be that the linker script doesn't declare the .data section to be within the flash MEMORY. Adding AT > FLASHto the end of the .data section declaration seems to fix the issue:
__etext = .;
.data :
    __data_start__ = .;
    *(vtable)
    *(.data*)
    . = ALIGN(4);
    __data_end__ = .;
} > RAM AT > FLASH
The start of the section seems a little bit suspicious to me too. What happens if __etext is not properly aligned?
