Configure TLM Frame type by default in Eddystone beacon - SDK 12.2.0
Hi, in the current project I'm working on, I need to develop an Eddystone beacon with UID and TLM frames configured by default. Based on the experimental_eddystone example, there is only one slot (slot 0) for configuring a default frame type. I successfully set it as UID frame type (in example it is URL type) and for configuring TLM frame type by default in slot 1, I modified es_slots.c. When I run the code on nRF51822xxAA and then scanning the device using nRFConnect, I receive both frame types, UID and TLM, but for TLM, voltage and temperature values are missed. However, after 2 and a half minutes, I started receiving voltage and temperature values.
When I test the same code on nRF52DK, TLM frame is OK since power-up so I'm not sure if the issue is related with changes I've made to es_slots.c or is something with ADC handling.
Is there any recommendation on how to set properly more than one slot with a default frame?
EDIT 1:
I've found that beacon starts sending real values of voltage and temperature when adv_cnt is 58-60, it is not time-related. In my first description I had an advertising interval in 5 seconds which results in 2 minutes and a half for 60 adv pkts (2.5 secs * 60 adv pkts = 150 secs). Then I test using 2 seconds as advertising interval, and after a minute, voltage and temperature values sent, were correct (1 sec * 60 adv pkts = 60 secs)
