Hi;
I am trying to secure DFU OTA. For that, i am using SDK12.2.0 and done with example file.
Now how to generate this .dat file itself.
Also explain each parameter of init file and how to set it.
Hi;
Thank you for your quick response.
I am using nRF Connect with android version 4.4.2.
Ok, can you attach the bootloader hex, application hex and the zip package that you created to the question `?
No, First i burn softdevice and bootloader hex using nRfgo studio then generate the zip package using above steps for update the application.
If you do not want to upload the hex files or the image you created then I suggest that you try to create a debug package, i.e.
nrfutil pkg generate --debug-mode --application dfu_test_app_hrm_s130.hex --key-file key.private app_dfu_package.zip"
Thank you for your reply.
But this command is also not working for me.
Also, I analysed that the example zip file size is 30,816 bytes and my zip file size is 30,870 bytes.
So, i hope it's doesn't matter.
