Hi;
I am trying to secure DFU OTA. For that, i am using SDK12.2.0 and done with example file.
Now how to generate this .dat file itself.
Also explain each parameter of init file and how to set it.
Hi;
Also i am trying to generate my own hex file for DFU OTA in mbed tool with shadow platform. First i am trying with BLE_LED example and select shadow platform. So, is there require any extra line into the code? Unfortunately it's also not working for me.
The zip file size should not matter. Have you tried using the default(i.e. unaltered secure bootloader) and performed an update with the test images in the examples\dfu\ble_dfu_send_hex\test_images_update_nrf51 folder? I am afraid that questions regarding the mbed implementation of our bootloader/DFU service should be posted on the mbed forums as we mainly support the nRF5x SDKs.
I am using dfu_test_softdevice_s130.hex for softdevice and dfu_test_bootloader_s130.hex for bootloader which is located in above path which you are mentained. and trying to update DFU using dfu_test_app_hrm_s130.hex file with own generated package.
Can you perform a successful DFU with the dfu_test_app_hrm_s130.zip image ?
Yes, i had done with dfu_test_app_hrm_s130.zip Can you suggest me any example file for testing DFU with own generated package?
