can you tell me how to detect low voltage in nrf51?? how to set lowest threshold??
Do you mean using the event / interrupt system.?
The other method is to use the ADC to measure the supply voltage, as the ADC has an input setting to measure the supply.
This question has been answered several times before
Take a look at these questions and the answers
Hi
You should be able to use the LPCOMP (low power comparator) for this.
You can set the threshold to VDD*N/8, where N is a whole number between 1 and 7. You can also use an external reference voltage, which could be provided by a voltage divider to give you an arbitrary threshold.
Best regards
Torbjørn
