NRF51DK disable transmission
I am using the ble_app_uart on the nrf51dk.RX is always enabled.I want to enable TX when data is to be transmitted and then disable it again.
I am using
NRF_UART0->TASKS_STOPTX = 1;
to disable transmission.
But when i use
NRF_UART0->TASKS_STARTTX = 1;
transmission is not enabled again..
Is there anything else that i have to write to Reenable transmission?
please help..
  • FormerMember
    0 FormerMember
    ble_app_uart uses the UART module (app_uart) for the UART communication. The UART module uses the UART driver, nrf_drv_uart.
    When I test the bare UART example in the "peripheral" folder, which also uses the UART module, it seems like writing directly to the register to doesn't work..
    However, calling nrf_drv_uart_tx_abort() should stop TX, and nrf_drv_uart_tx() should start TX. To call the nrf_drv_uart_xx functions, you will need the instance structure (or a pointer to it). I haven't tested it, but it's worth a try.
  • FormerMember
    0 FormerMember
