I have set up raspberry pi 3 as a border router and programmed the the nrf51422 using the iot_ipv6_coap_server_pca10028 and could successfully switch on and off led3 and led4 using copper coap client on a local area network.
Do you have native IPv6 connectivity? Are you able to ping ipv6.google.com from the RPi3?
I do not have ipv6 connectivity .I only have ipv4 connectivity .Is there any method to access it from the internet so i can access the nrf51dk from a remote location.
Ok. Then you need a IPv6 tunnel, for example 6to4 or Hurricane.
in step (6) which ipv6 addresse should i assign in the last two lines of the interfaces file?
The address from the tunnel details.
