SAADC Sample Convert Bug
I am using the SAADC on the nRF52832, SDK12.2.0, with it set to 12 bits and low power mode. I have enabled five channels which I run blocking nrf_drv_saadc_sample_convert conversions on periodically, currently once a second.
When I print the results out via RTT every second sample is incorrect. I have looked at both my conversion math and the counts value and the problem is in the count value returned from the ADC. See below, the converted result should be ~2.4V but i get 2.4V, then one second later 4.4V.
2.396097
4.437609
2.392563
4.437609
2.390207
4.444677
I added a print statement to see if the interrupt being called (which it shouldn't since it's disabled in the call to nrf_drv_saadc_sample_convert but to my surprise it was being called.
SAADC_EVENT STARTED 2.396097
SAADC_EVENT STARTED 4.437609
SAADC_EVENT STARTED 2.392563
SAADC_EVENT STARTED 2.390207
SAADC_EVENT STARTED 4.444677
Taking closer look at nrf_drv_saadc_sample_convert I found that a call to nrf_saadc_event_clear(NRF_SAADC_EVENT_STARTED) is required after the conversion is finished.
Here is my patch for nrf_drv_saadc_sample_convert
@@ -333,6 +333,7 @@
         timeout--;
+    nrf_saadc_event_clear(NRF_SAADC_EVENT_STARTED);
     nrf_saadc_event_clear(NRF_SAADC_EVENT_END);
     if (m_cb.active_channels > 1)
This bug also seems to be in SDK 13.0.0-1.alpha.
Can someone from Nordic please comment on my proposed solution?
EDIT Feb. 7,/17 : Attaching a main.c that demonstrates the issue. This main.c is modified version of SDK12.2.0 blinky_FreeRTOS example.
main.c
Cheers, Darren
  • Hi, I'm not able to reproduce this problem. Can you please upload an example project showing this issue?
  • Jorgen,
    Did you initialize more than one channel? I have have setup and I am not un-initing them between conversions. Let me know if you still have the issue and I will put something together using a DK.
    Cheers, Darren
  • I did not initialize more than one channel, as I could not read this out from your initial problem description. I tested with two channels now, and still not seeing this issue. Would be great if you could upload an example illustrating the issue.
  • Jorgen,
    Sorry, after re-reading my initial post I realized I missed the word five channels.
    Anyway I have been able to reproduce the problem on a PCA10040 DK. Interestingly the problem doesn't occur when I convert the channel assigned to convert VDD or AIN1 but it happens when I select AN2.
    On the DK I have tied P0.03 to VDD and P0.04 to GND via jumpers. I will attach the main.c above.
    Cheers, Darren
  • Thanks, I see the same pattern that you do. I have reported this issue internally.
1 2
