scanning and connection establishment parameters
I have a question about scan window and interval [I'm using nrf51822aa with s130 2.0.1... I performing some tests and I find a use case: If I set both of them (scan interval and window) to 0x140 - 200ms then radio scans all the time, after that I stop the scanning and create connection...
Once I get event that connection is established (with connection interval 20ms) I would like to start scanning once again - with same scanning params (interval 200ms and window 200ms) - What is from my perspective not possible because scanning procedure could not use radio for 100% if connection is established... but softdevice allows me to use such params (I get NRF_SUCCESS) - even it's not possible to work with such params or am I wrong? Of course none of device is found - once I use a bit more reasonable params (interval 200ms, window 50ms) everything works just fine
Now I am wondering how is this solved/protected in softdevice that user can set such things for scanning or creating connection params?
I expose softdevice functions to end user via API with all supported params, but I see that user could also enter/trigger some strange behaviour... Should I limited user at entering params considering on number of established connections?
Thank you for info.
Best regards, Matej
  • Yes, the SoftDevice will accept such parameters even though it has a connection. It will schedule connection and scanning events. See this for more information about scheduling.
    The SoftDevice does not protect against this, it expect the user to select paramters that make sense.
    I absolutely think it makes sense to limit the parameters the user can enter.
  • News about what? :)
    It is possible to tell the SoftDevice to use those parameters, but it will of course not be able to scan 100% of the time and maintain a connection, the scanning and connection events will be scheduled according to the chapter you linked to. I don't see how you end up with expecting NRF_ERROR_RESOURCES by reading that chapter, could you explain a bit more?
    The peripheral connection isn't necessarily terminated, but it depends a bit on the connection parameters. It can hit the supervision timeout and get linkloss. I don't have any other suggestions than limiting the user to enter such parameters.
