Connection to Android isn't stable
I'm having an issue with maintaining a stable connection with the master control panel on an android device. Using the PCA10000 I am able to get a stable connection with a computer and transmit data, but when I move to an android device it isn't stable.
I started with the example project "nrf51-ble-app-lbs-throughput-test-5.1.0" and instead of continuously transmitting on a button event, I added a timer which triggers every 30ms to transmit 9 bytes acquired from an I2C sensor. It continues to do this until the button is pressed again.
On the android device I can connect to it, but as soon as I press the button to start sending data the connection is lost and the error returned from the transmit function, ble_lbs_data_send(), is 0x3401.
I am using the nRF51822 development kit with the SoftDevice s110, Keilv5 evaluation version. I have also stopped the sensors from measuring and am transmitting dummy data, which doesn't change the error at all.
Thanks, Jeremy
