I am having trouble with buttonless DFU on my application. I am working on custom hardware on the nRF51822, SDK10.0.0, S130.
When I enter DFU from my application the application goes through the reset_prepare sequence I created but then does not proceed to the bootloader. I know that I am definitely reaching the end of my custom reset_prepare sequence so it appears to be after that.
Any advice as to why I am not getting to bootloader mode would be much appreciated.
My reset_prepare function is as follows:
static void ble_peripheral_reset_prepare(void)
uint32_t err_code;
err_code = ble_conn_params_stop();
dfu_reset_prepare();
And the main in my bootloader application is:
uint32_t err_code;
bool dfu_start = false;
bool app_reset = (NRF_POWER->GPREGRET == BOOTLOADER_DFU_START);
bool pin_wakeup = ((NRF_POWER->RESETREAS & POWER_RESETREAS_OFF_Msk) == POWER_RESETREAS_OFF_Msk);
if (app_reset)
NRF_POWER->GPREGRET = 0;
leds_init();
// This check ensures that the defined fields in the bootloader corresponds with actual
// setting in the nRF51 chip.
APP_ERROR_CHECK_BOOL(*((uint32_t *)NRF_UICR_BOOT_START_ADDRESS) == BOOTLOADER_REGION_START);
APP_ERROR_CHECK_BOOL(NRF_FICR->CODEPAGESIZE == CODE_PAGE_SIZE);
// Initialize.
timers_init();
buttons_init();
(void)bootloader_init();
if (bootloader_dfu_sd_in_progress())
nrf_gpio_pin_clear(UPDATE_IN_PROGRESS_LED);
nrf_gpio_pin_clear(UPDATE_IN_PROGRESS_LED_2);
err_code = bootloader_dfu_sd_update_continue();
ble_stack_init(!app_reset);
scheduler_init();
err_code = bootloader_dfu_sd_update_finalize();
nrf_gpio_pin_set(UPDATE_IN_PROGRESS_LED);
nrf_gpio_pin_set(UPDATE_IN_PROGRESS_LED_2);
// If stack is present then continue initialization of bootloader.
scheduler_init();
dfu_start = app_reset;
dfu_start |= ((nrf_gpio_pin_read(BOOTLOADER_BUTTON) == 0) ? true: false);
dfu_start &= ((!pin_wakeup) ? true: false);
if (dfu_start || (!bootloader_app_is_valid(DFU_BANK_0_REGION_START)))
// Initiate an update of the firmware.
err_code = bootloader_dfu_start();
if (bootloader_app_is_valid(DFU_BANK_0_REGION_START) && !bootloader_dfu_sd_in_progress())
// Select a bank region to use as application region.
// @note: Only applications running from DFU_BANK_0_REGION_START is supported.
bootloader_app_start(DFU_BANK_0_REGION_START);
NVIC_SystemReset();
