NRF sniffer UART baud rate
Hi, I'm trying to use an MDBT40 based board as a sniffer using the NRF sniffer firmware. I'm guessing I just need UART -> USB to talk to the chip, so I've hooked it up to an Arduino which is basically reading from UART and writing to USB console (and the other way around).
I flashed the firmware to the MDBT40 module. Do I need to flash the softdevice also?
I'm getting data through, but at this point it's just rubbish. What is the UART baud rate in the sniffer firmware? Is the sniffer source code available somewhere?
  • @dingari: The sniffer firmware uses 460800bps baudrate. But what do you plan to use on PC side to interface with the sniffer ? If you use our sniffer console, you don't need to set the baudrate, it's selected automatically by the sniffer console software. We provide the Sniffer API, that you can use if you plan to make/integrate your own sniffer software.
