timer 1 exiper faster
hi all,
i try to use to timer to have a single press and a long press. this my code.
const nrf_drv_timer_t TIMER_BUTTON = NRF_DRV_TIMER_INSTANCE(0);
const nrf_drv_timer_t TIMER_BUTTON_LONG_PUSH = NRF_DRV_TIMER_INSTANCE(1);
void TIMER_CreateDebounce(nrf_timer_event_handler_t  DRV_TIMER_EventHandler)
  uint32_t  time_ticks;
   nrf_drv_timer_init(&TIMER_BUTTON, NULL, DRV_TIMER_EventHandler);
   time_ticks = nrf_drv_timer_ms_to_ticks(&TIMER_BUTTON, TIMER_DEBOUNCE_DELAY);
   nrf_drv_timer_extended_compare(
   &TIMER_BUTTON, NRF_TIMER_CC_CHANNEL0, time_ticks, NRF_TIMER_SHORT_COMPARE0_CLEAR_MASK, true);
/**@brief        Create a Timer
* @param [in]  TIMER_Id_t - IdTimer
* @param [in]  app_timer_mode_t - Mode TImer
* @param [in]  TIMER_TimerCallback - Callback to Call when the timer expires
* @retval    uint32_t; Return error
void TIMER_LongPressCreate(nrf_timer_event_handler_t  DRV_TIMER_EventHandlerLongPress)
   uint32_t  time_ticks2;
   nrf_drv_timer_init(&TIMER_BUTTON_LONG_PUSH, NULL, DRV_TIMER_EventHandlerLongPress);
   time_ticks2 = nrf_drv_timer_ms_to_ticks(&TIMER_BUTTON_LONG_PUSH, TIMER_PUSH_TIMEOUT_MS);
   &TIMER_BUTTON_LONG_PUSH, NRF_TIMER_CC_CHANNEL1, time_ticks2, NRF_TIMER_SHORT_COMPARE1_CLEAR_MASK, true);
/**@brief    TIMER_Stop
* @param [in]  TIMER_Id_t - Id Timer
* @retval    uint32_t; Return error code
void TIMER_Stop(void)
   nrf_drv_timer_disable(&TIMER_BUTTON);
/**@brief        Start Timer
* @param [in]  uint64_t - Delay Timer after tha callback is called
* @param [in]  void * - Pointer use to pass a variable to callback
void TIMER_Start(void)
   nrf_drv_timer_enable(&TIMER_BUTTON);
void TIMER_StopLongPress(void)
   nrf_drv_timer_disable(&TIMER_BUTTON_LONG_PUSH);
void TIMER_StartLongPress(void)
   nrf_drv_timer_enable(&TIMER_BUTTON_LONG_PUSH);
but timer 1 exipres faster. Some have an idea about that? thanks, Anna
