sd_ble_gatts_hvx datasize error
Hi, I try to modifie ble_multilink example et send more than one data, here is my main code code :
 static uint8_t test[4] = {0x41, 0x42, 0x43, 0x44};
 static uint16_t testLen = 4;
        memset(&params, 0, sizeof(params));
        params.type = BLE_GATT_HVX_NOTIFICATION;
        params.handle = m_lbs.button_char_handles.value_handle;
        params.offset = 0;
        //params.p_data = test;
        params.p_data = (uint8_t*)(&test[0]);
        params.p_len = &testLen;
        err_code = sd_ble_gatts_hvx(m_lbs.conn_handle, &params);
The problem is that sd_ble_gatts_hvx() retrun NRF_ERROR_DATA_SIZE, and I can't get why.
any idea ?
  • FormerMember
    0 FormerMember
    When I test the exact same parameters here using ble_app_hrs, is works fine, sd_ble_gatts_hvx(..) returns NRF_SUCCESS.
    Which version of the SDK and softdevice do you use?
  • Thanks for answering. I use s130 and SDK v11, but I found what was wrong. In ble_lbs.c there is a function static uint32_t button_char_add(ble_lbs_t * p_lbs, const ble_lbs_init_t * p_lbs_init) wich I think is used to init sd_ble_gatts_hvx().
    In this function I replaced this :
    attr_char_value.p_uuid       = &ble_uuid;
    attr_char_value.p_attr_md    = &attr_md;
    attr_char_value.init_len     = sizeof(uint8_t);
    attr_char_value.init_offs    = 0;
    attr_char_value.max_len      = sizeof(uint8_t);
    attr_char_value.p_value      = NULL;
    with this :
    attr_char_value.init_len     = 6*sizeof(uint8_t);
    attr_char_value.max_len      = 6*sizeof(uint8_t);
    And know I can send data.
