Battery service outputs 100% no matter what
Hi DevZone
I am trying to measure the battery voltage using the bas service. I got some hints from the ble_app_proximity example.
My problem is that no matter what the output is 100% (And yes it is tested on a CR2032 with 2.8V, so it should be more like 30%ish).
My saadc event hander is:
void saadc_event_handler(nrf_drv_saadc_evt_t const * p_event)
        nrf_saadc_value_t adc_result;
        uint16_t          batt_lvl_in_milli_volts;
        uint8_t           percentage_batt_lvl;
        uint32_t          err_code;
        adc_result = p_event->data.done.p_buffer[0];
				SEGGER_RTT_printf(0, "adc_result: %d\n", adc_result);
        err_code = nrf_drv_saadc_buffer_convert(p_event->data.done.p_buffer, 1);
        batt_lvl_in_milli_volts = ADC_RESULT_IN_MILLI_VOLTS(adc_result) +
                                  DIODE_FWD_VOLT_DROP_MILLIVOLTS;
        percentage_batt_lvl = battery_level_in_percent(batt_lvl_in_milli_volts);
        err_code = ble_bas_battery_level_update(&m_bas, percentage_batt_lvl);
        if (
            (err_code != NRF_SUCCESS)
            (err_code != NRF_ERROR_INVALID_STATE)
            (err_code != BLE_ERROR_NO_TX_PACKETS)
            (err_code != BLE_ERROR_GATTS_SYS_ATTR_MISSING)
            APP_ERROR_HANDLER(err_code);
and the adc initialization:
static void adc_configure(void)
	  ret_code_t err_code = nrf_drv_saadc_init(NULL, saadc_event_handler);
	nrf_saadc_channel_config_t config =
        NRF_DRV_SAADC_DEFAULT_CHANNEL_CONFIG_SE(NRF_SAADC_INPUT_VDD);
    err_code = nrf_drv_saadc_channel_init(0, &config);
    err_code = nrf_drv_saadc_buffer_convert(&adc_buf[0], 1);
    err_code = nrf_drv_saadc_buffer_convert(&adc_buf[1], 1);
The result in nRF connect:
nRF connect
Can anybody point me in the right direction? I am a bit lost where my problem is.
Btw. I am using the PCA10056 (NRF52840 PDK) and SDK12.20 :-)
Best Regards Mathias
  • Sorry, but i am a little confused over the notification thing. Where should i enable notifications? Is it in my bas_init?
        static void bas_init(void)
    { uint32_t err_code; ble_bas_init_t bas_init_obj;
    memset(&bas_init_obj, 0, sizeof(bas_init_obj));
    bas_init_obj.evt_handler          = on_bas_evt;
    bas_init_obj.support_notification = true;
    bas_init_obj.p_report_ref         = NULL;
    bas_init_obj.initial_batt_level   = 100;
    BLE_GAP_CONN_SEC_MODE_SET_OPEN(&bas_init_obj.battery_level_char_attr_md.cccd_write_perm);
    BLE_GAP_CONN_SEC_MODE_SET_OPEN(&bas_init_obj.battery_level_char_attr_md.read_perm);
    BLE_GAP_CONN_SEC_MODE_SET_NO_ACCESS(&bas_init_obj.battery_level_char_attr_md.write_perm);
    BLE_GAP_CONN_SEC_MODE_SET_OPEN(&bas_init_obj.battery_level_report_read_perm);
    err_code = ble_bas_init(&m_bas, &bas_init_obj);
