Do I need a Balun for very short range?
I'm using a 51422 for a very short range, fixed system. I will never need the chip to receive or be received from more than 5 meters away, and more often just 2-3 meters. On my custom PCB the two antenna pins (ANT1, ANT2) are unconnected and facing the edge of the board, with a ground plane under the 51422 on the opposite side of the PCB. The reference design on the site seems to assume that builders want maximum transmission distance. Since my range is so short, do I need a Balun or an antenna at all? Or is the fact that the chip is on the edge of the board with no obstructions good enough?
