I'm trying to make the nRF51422xxAC advertise. Using Segger Embedded Studio.
I have this code: bpaste.net/.../f29f74986c10
On line 109, I have a breakpoint. At that point in the code, err_code = 4, and after that, the nRF resets.
#define NRF_ERROR_NO_MEM (NRF_ERROR_BASE_NUM + 4)
No Memory for operation.
I have tried with different SRAM_START in the Linker settings: from 0x20001FE8 up to 0x20007000. The chip should have 0x8000 bytes of memory if I read correctly. Anyway - I get the same behaviour every attempt.
I have looked at other forum posts but haven't found anything directly applicable. Line 105 is from trying one of the solutions to no avail.
From the softdevice_enable documentation:
If the app_ram_base is too low, this function will return an error. Using a app_ram_base that is too high will not fail, but will result in RAM that is never used
But I can't find any further information on how much memory is needed. However, I would be surprised if a bigger SRAM_START than 0x20007000 is needed... The problem is probably something else.
