Digital input pin voltage drop while using no pull config
Hi I'm using nrf51822 with soft device 11.0 & want to read a 12 volt digital signal for this I'm converting 12v to 3v3 (4.5 & 1.5 Kohm Resistor) using voltage divider ckt but my voltage level is around 1v4 if I remove the pin from nrf then the voltage is around 3v3.
here is config: nrf_gpio_cfg_input(IGT_PIN, NRF_GPIO_PIN_NOPULL);
For reading: nrf_gpio_pin_read(IGT_PIN)
I Aslo try with pull up config but facing same problem
