gpiote sense high frequency signal
I want to implement simple module:
  1. gpiote event on pin change (around 6.7MHz signal)
  2. Route gpiote event through PPI to increment counter
  3. Toggle GPIO pin on Compare event
Im using this code (modified example of 8mhz-pwm), but it doesn't seem to work properly. Is there any way to capture such high frequency signal?
nrf_gpio_range_cfg_output(LED_0, LED_1);
nrf_gpio_pin_set(LED_0);
while (NRF_CLOCK->EVENTS_HFCLKSTARTED == 0)
// Workaround for PAN item 11, nRF51822-PAN v2.0.pdf. Not needed on second revision chips.
NRF_POWER->TASKS_CONSTLAT = 1;
nrf_gpio_cfg_sense_input(BUTTON_0, NRF_GPIO_PIN_PULLDOWN, NRF_GPIO_PIN_SENSE_HIGH);
NRF_GPIOTE->CONFIG[0] = GPIOTE_CONFIG_MODE_Task << GPIOTE_CONFIG_MODE_Pos |
                        GPIOTE_CONFIG_POLARITY_Toggle << GPIOTE_CONFIG_POLARITY_Pos |
                        LED_1 << GPIOTE_CONFIG_PSEL_Pos |
                        GPIOTE_CONFIG_OUTINIT_Low << GPIOTE_CONFIG_OUTINIT_Pos;
NRF_GPIOTE->CONFIG[1] = GPIOTE_CONFIG_MODE_Event << GPIOTE_CONFIG_MODE_Pos |
                        GPIOTE_CONFIG_POLARITY_HiToLo << GPIOTE_CONFIG_POLARITY_Pos |
                        BUTTON_0 << GPIOTE_CONFIG_PSEL_Pos;
NRF_TIMER1->PRESCALER = 0;
// Adjust the output frequency by adjusting the CC.
// Due to PAN item 33, you can't have this at 1 for first revision chips, and will hence be limited to 4 MHz.
NRF_TIMER1->CC[0] = 1;
NRF_TIMER1->SHORTS = TIMER_SHORTS_COMPARE0_CLEAR_Enabled << TIMER_SHORTS_COMPARE0_CLEAR_Pos;
NRF_TIMER1->TASKS_START = 1;
NRF_TIMER2->MODE = TIMER_MODE_MODE_Counter;
NRF_TIMER2->TASKS_CLEAR = 1;
NRF_TIMER2->BITMODE = TIMER_BITMODE_BITMODE_16Bit;
NRF_TIMER2->CC[0] = 10;
NRF_TIMER2->TASKS_START = 1;
NRF_TIMER2->SHORTS = (TIMER_SHORTS_COMPARE0_CLEAR_Enabled << TIMER_SHORTS_COMPARE0_CLEAR_Pos);
// NRF_PPI->CH[0].EEP = (uint32_t) &NRF_TIMER1->EVENTS_COMPARE[0];
NRF_PPI->CH[0].EEP = (uint32_t) &NRF_GPIOTE->EVENTS_IN[1];
NRF_PPI->CH[0].TEP = (uint32_t) &NRF_TIMER2->TASKS_COUNT;
NRF_PPI->CH[1].EEP = (uint32_t) &NRF_TIMER2->EVENTS_COMPARE[0];
NRF_PPI->CH[1].TEP = (uint32_t) &NRF_GPIOTE->TASKS_OUT[0];
NRF_PPI->CHENSET = PPI_CHENSET_CH0_Enabled << PPI_CHENSET_CH0_Pos;
NRF_PPI->CHENSET = PPI_CHENSET_CH1_Enabled << PPI_CHENSET_CH1_Pos;
while (true)
    NRF_TIMER2->TASKS_CAPTURE[2] = 1;
    NRF_LOG_PRINTF("cc[2] = %d\n", NRF_TIMER2->CC[2]);
    nrf_delay_ms(200);
