experimental_ble_app_buttonless_dfu
nrf52832 sdk12.2.0 s132.3.1
Hello. Can't write properties after flash experimental_ble_app_buttonless_dfu example into chip. I can only enter into bootloader using button, but enter by enable notification and writing 1 to this service do not (I don't have this properties is enable). there was the same problem I think devzone.nordicsemi.com/.../ but after adding
 char_md.char_props.write = 1;
into ble_dfu.c in the function rx_char_add() not solved my problem. I still can't see write properties for dfu_buttonless service
image description image description
Parents Reply
  • I think the problem was refer to cashe you were right. It's work with both yours and mine now (actually sdk example) code. Thanks. Also I'd like to say thanks a bunch to Nordic workers for so exciting dfu library. I tried to brake down loading (disconnecting, reset and etc) the old code is work in any case and even more, when I try to repeat uploading the new code its start from the end of last try. It's very smart and useful feature I think, because If my chip loacate far enougth from me and the connection is poor. I can update firmware in several parts (10% each time or less for example). Maybe I exaggerating a little but It's awesome in any case.
