Compiling nRF51822 bootloader example using GCC
Hi, I'm trying to compile the bootloader example using GCC instead of Keil compiler.
To do so, I copied the bootloader example and started editing the file bootloader_util_arm.c, in particular I've changed:
__asm void StartApplication(uint32_t start_addr)
    LDR   R2, [R0]
    MSR   MSP, R2
    LDR   R3, [R0, #0x00000004]
    BX    R3
    ALIGN
in
	asm volatile (
    	"LDR   R2, [R0] \n\t"
    	"MSR   MSP, R2 \n\t"
    	"LDR   R3, [R0, #0x00000004] \n\t"
    	"BX    R3 \n\t"
    	".align \n\t"
Then I changed
uint8_t  m_boot_settings[CODE_PAGE_SIZE] __attribute__((at(BOOTLOADER_SETTINGS_ADDRESS))) __attribute__((used));
uint32_t m_uicr_bootloader_start_address __attribute__((at(NRF_UICR_BOOT_START_ADDRESS))) = BOOTLOADER_REGION_START;
in
uint8_t  m_boot_settings[CODE_PAGE_SIZE] __attribute__((section(".bootloader_settings"))) __attribute__((used));
uint32_t m_uicr_bootloader_start_address __attribute__((section(".bootloader_addr"))) __attribute__((used)) = BOOTLOADER_REGION_START;
And now, I need to edit the linker script in order to add the sections used above, so I've copied the two linker scripts gcc_nrf51_common.ld and gcc_nrf51_s110_xxaa.ld and edited like this.
gcc_nrf51_s110_xxaa.ld:
/* Linker script to configure memory regions. */
SEARCH_DIR(.)
GROUP(-lgcc -lc -lnosys)
MEMORY
  FLASH (rx) : ORIGIN = 0x00014000, LENGTH = 0x2C000
  UICR (rwx) : ORIGIN = 0x10001000, LENGTH = 0x18
  RAM  (rwx) : ORIGIN = 0x20002000, LENGTH = 0x2000
INCLUDE "gcc_nrf51_common.ld"
gcc_nrf51_common.ld:
ENTRY(Reset_Handler)
SECTIONS
	.text :
		KEEP(*(.Vectors))
		*(.text*)
		*(.init)
		*(.fini)
		/* .ctors */
		*crtbegin.o(.ctors)
		*crtbegin?.o(.ctors)
		*(EXCLUDE_FILE(*crtend?.o *crtend.o) .ctors)
		*(SORT(.ctors.*))
		*(.ctors)
		/* .dtors */
 		*crtbegin.o(.dtors)
 		*crtbegin?.o(.dtors)
 		*(EXCLUDE_FILE(*crtend?.o *crtend.o) .dtors)
 		*(SORT(.dtors.*))
 		*(.dtors)
		*(.rodata*)
		*(.eh_frame*)
	} > FLASH
	.ARM.extab :
		*(.ARM.extab* .gnu.linkonce.armextab.*)
	} > FLASH
	__exidx_start = .;
	.ARM.exidx :
		*(.ARM.exidx* .gnu.linkonce.armexidx.*)
	} > FLASH
	__exidx_end = .;
	.bootloader_settings 0x0003FC00 :
		KEEP(*(.bootloader_settings))
	} > FLASH
	__etext = .;
	.bootloader_addr 0x10001014 :
		KEEP(*(.bootloader_addr))
	} > UICR
	.data : AT (__etext)
		__data_start__ = .;
		*(vtable)
		*(.data*)
		. = ALIGN(4);
		/* preinit data */
		PROVIDE_HIDDEN (__preinit_array_start = .);
		*(.preinit_array)
		PROVIDE_HIDDEN (__preinit_array_end = .);
		. = ALIGN(4);
		/* init data */
		PROVIDE_HIDDEN (__init_array_start = .);
		*(SORT(.init_array.*))
		*(.init_array)
		PROVIDE_HIDDEN (__init_array_end = .);
		. = ALIGN(4);
		/* finit data */
		PROVIDE_HIDDEN (__fini_array_start = .);
		*(SORT(.fini_array.*))
		*(.fini_array)
		PROVIDE_HIDDEN (__fini_array_end = .);
		*(.jcr)
		. = ALIGN(4);
		/* All data end */
		__data_end__ = .;
	} > RAM
	.bss :
		. = ALIGN(4);
		__bss_start__ = .;
		*(.bss*)
		*(COMMON)
		. = ALIGN(4);
		__bss_end__ = .;
	} > RAM
	.heap (COPY):
		__end__ = .;
		end = __end__;
		*(.heap*)
		__HeapLimit = .;
	} > RAM
	/* .stack_dummy section doesn't contains any symbols. It is only
	 * used for linker to calculate size of stack sections, and assign
	 * values to stack symbols later */
	.stack_dummy (COPY):
		*(.stack*)
	} > RAM
	/* Set stack top to end of RAM, and stack limit move down by
	 * size of stack_dummy section */
	__StackTop = ORIGIN(RAM) + LENGTH(RAM);
	__StackLimit = __StackTop - SIZEOF(.stack_dummy);
	PROVIDE(__stack = __StackTop);
	/* Check if data + heap + stack exceeds RAM limit */
	ASSERT(__StackLimit >= __HeapLimit, "region RAM overflowed with stack")
Then in the Makefile I specified the linker scripts to use when building the executable.
Compilation and linking goes fine, without any errors, but the resulting executable has a size of 256MB!
I found that the problem seems to be the KEEP(*(.bootloader_addr)), because if I cut out this, I get an executable of 176KB, but if I remove the KEEP instruction the linker discards the bootloader_addr section (I checked this running the arm-none-eabi-nm on the .out executable).
WIth the KEEP instruction (.bin file has size of 256MB), running the command nm:
arm-none-eabi-nm _build/dfu_single_bank_ble_s110.out | sort
00040000 D __etext
10001014 D m_uicr_bootloader_start_address
20002000 D __data_start__
Without the KEEP instruction (.bin file has size of 176KB), I get:
00040000 D __etext
I'm new with linker scripts and I suspect that my modified ld scripts could have some bugs or I have made some mistakes somewhere... but I don't know where to search the error that makes the executable become 256MB...
Thanks for any help/support.
Regards, Samuele.
  • I'd recommend you to take a look at this question.
    The bootloader hex is set up to write to a UICR register, which is mapped at 0x10001014, in addition to the normal code at around address 0. The difference between those are about 256 MB, so for any format that doesn't allow address jumps, you'll see a 256 MB file with almost all 0s. This is the case for raw binary files, but not for elf files or hex files, which include addressing information.
    This is also the reason that the Makefile here, that flash the softdevice, splits the hex into two different binaries before writing it to the chip; one with the main flash contents and one with UICR contents.
  • Hi, thanks for your answer.
    Ok, I've understood the problem related to the 256MB file size, but I still have some doubts.
    As I understand, to start the bootloader firmware (that resides at some address in flash around 0x03C800) it is needed that the UICR->BOOTLOADERADDR register is loaded with the bootloader firmware start address. How can I load this address into the UICR->BOOTLOADERADDR? Do I need to split the UICR section of my executable file and load that piece of bin separately, similar as is done for the s110?
    In the other thread you suggested, the second solution provided by Nikita seems to be similar to the one I have adopted, but there isn't any reference to big executable size using this method.
    Samuele.
  • Yes, you'll have to split the file using objcopy, and then write both the main part and the UICR part with JLinkExe. You may have to use objdump to see which sections are in your elf file, and where they're supposed to be located. If you have trouble with this, I suggest you post it separately, as it is really an unrelated problem.
    It seems the others are on Windows, on which you can use nrfjprog to program insted of JLinkExe directly. nrfjprog supports programming hex files directly, avoiding the need for bin files completely, and is hence more usable in that regard.
