Intentional over-voltage on nRF52 I/O Pin?
Hi all --
I have an application where I have a LDO generating 2.6V from a single lithium-ion cell. It has an EN input that I want to expose to the nRF52 with a little RC circuit to allow the nRF52 to trigger its own power-cycle, if desired.
The EN pin on the LDO will be pulled up to the battery rail through a 100kOhm resistor. The nRF would drive a low on this net to cause a cycle to happen. Worst-case, I could source a maximum of 42uA across that resistor into a nRF I/O pin.
Is this enough current (~40uA) to cause permanent damage to the device? I've had other MCUs where with a large resistor, "higher" voltages could be present at the pin due to the large impedance presented.
