How to set Service UUID for central and peripheral
Hi. I'm using nRF51822AC, SDK12.2.0, S130 as central and peripheral.
Q1. What's "sd_ble_uuid_vs_add" function? is it for setting service UUID? Q2. If Q1 yes, how to change service uuid?
for example) I want to set service uuid as below.
For central : #define LBS_UUID_BASE {0x23, 0xD1, 0xBC, 0xEA, 0x5F, 0x78, 0x23, 0x15,
0xDE, 0xEF, 0x12, 0x12, 0x00, 0x00, 0x00, 0x00}
For periphral : #define p_BASE_UUID {0x00, 0x00, 0x00, 0x30, 0x52, 0xD0, 0x00, 0x00, 0, 1, 2, 3, 4, 5, 6, 7}
and I made source code as below. ......
ble_uuid128_t lbs_base_uuid = {LBS_UUID_BASE};
err_code = sd_ble_uuid_vs_add(&lbs_base_uuid, &p_ble_lbs_c->uuid_type);
if (err_code != NRF_SUCCESS)
    return err_code;
VERIFY_SUCCESS(err_code);
ble_uuid128_t p_base_uuid = p_BASE_UUID;
err_code = sd_ble_uuid_vs_add(&p_base_uuid, &p_m_p->uuid_type);
    return err_code;
But it's service UUID in advertising data is LBS_UUID_BASE.
How can I set p_BASE_UUID in advertising data?
I need your help.
    The function sd_ble_uuid_vs_add() is described in the infocenter. The UUIDs in the stack is not put into the advertising data by default, you have to add it yourself.
    If you application advertise the LBS UUID and you are using one of the examples from the SDK (ble_app_blinky?), it is most likely added to the advertising data in advertising_init() function. You can have a look at the ble_app_uart example, as this shows how to advertise a custom UUID.
    If you connect to your peripheral and perform a service discovery, do you see your custom service?
    Jørgen
  • If you add multiple BASE_UUIDs to the stack using sd_ble_uuid_vs_add(), you have to set the UUID type to the correct number.
    In ble_app_uart example, the UUID type is set to BLE_UUID_TYPE_VENDOR_BEGIN, as there is only one vendor specific base UUID added to the stack. If you add multiple base UUIDs, you will have to set the UUID type in the order the base UUIDs are added to the stack:
    If you have two vendor specific services that you want to advertise, defined like this:
    #define NUS_BASE_UUID					{{0x9E, 0xCA, 0xDC, 0x24, 0x0E, 0xE5, 0xA9, 0xE0, 0x93, 0xF3, 0xA3, 0xB5, 0x00, 0x00, 0x40, 0x6E}}
    #define LBS_UUID_BASE        			{{0x23, 0xD1, 0xBC, 0xEA, 0x5F, 0x78, 0x23, 0x15, 0xDE, 0xEF, 0x12, 0x12, 0x00, 0x00, 0x00, 0x00}}
    #define BLE_UUID_NUS_SERVICE 			0x0001
    #define LBS_UUID_SERVICE				0x1523
    Your UUID types should be:
    #define NUS_SERVICE_UUID_TYPE      		BLE_UUID_TYPE_VENDOR_BEGIN
    #define LBS_SERVICE_UUID_TYPE			BLE_UUID_TYPE_VENDOR_BEGIN + 1
    And you should add the base UUIDs to the stack in this order:
    sd_ble_uuid_vs_add(NUS_BASE_UUID)
    sd_ble_uuid_vs_add(LBS_UUID_BASE)
    You can then add the two UUIDs, with different base UUIDs, to the advertising/scan response packet:
    static ble_uuid_t                       m_adv_uuids[] = {{BLE_UUID_NUS_SERVICE, NUS_SERVICE_UUID_TYPE},{LBS_UUID_SERVICE, LBS_SERVICE_UUID_TYPE}};
    advdata.uuids_more_available.uuid_cnt = 1;
    advdata.uuids_more_available.p_uuids  = &m_adv_uuids[0];
    scanrsp.uuids_more_available.uuid_cnt = 1;
    scanrsp.uuids_more_available.p_uuids  = &m_adv_uuids[1];
