How to determine if a disconnection is due to a bad signal (signal loss)
I am trying to detect if a disconnection occurs due to a signal loss.
In the application's BLE Stack event handler, I have found that there is a disconnect reason in the ble_evt_t parameter : p_ble_evt->evt->gap_evt->params->disconnected->reason
In case of proper disconnection from peripheral or central, I have got 0x13 or 0x16 which are correct values accordign to the SDK : devzone.nordicsemi.com/.../a01162.html
But the reason value is never the same (0x90, 0x8F, 0x4E, ... not initialized?) in case of disconnection due to a bad signal, I don't find any constant in the documentation for this case.
Is there a possibility to know that a disconnection occurs due to a signal loss?
Thanks
