how to get UART example using nRF24LU1+
I have a example using nRF24LE1. So. I want know what can I change that example. or how to I get nRF24LU1+ example.
nRF24LE1 example is this.
/* Copyright (c) 2009 Nordic Semiconductor. All Rights Reserved. *
  • The information contained herein is confidential property of Nordic
  • Semiconductor ASA.Terms and conditions of usage are described in detail
  • in NORDIC SEMICONDUCTOR STANDARD SOFTWARE LICENSE AGREEMENT.
  • Licensees are granted free, non-transferable use of the information. NO
  • WARRENTY of ANY KIND is provided. This heading must NOT be removed from
  • the file.
  • $LastChangedRevision: 133 $ */
/** @file
  • @brief UART example
  • @defgroup uart_example UART "Hello World" example
  • @ingroup nrf_examples
  • @brief This example writes the string "Hello World" on start-up. After this all
  • characters received on the RXD input are echoed to the TXD output.
  • The example implements the low level stdio functions putchar() and getchar() so that standard
  • IO functions such as printf() and gets() can be used by the application.
//lint -e732 //lint -e713 //lint -e640
#include <stdio.h> #include "nrf24le1.h" #include "hal_uart.h" #include "hal_clk.h"
// Cusomization of low level stdio function. Used by for example printf(). #ifdef ICC8051 int putchar(int c) #else /presume C51 or other accepting compilator/ char putchar(char c) #endif { hal_uart_putchar(c); return c; }
// Cusomization of low level stdio function. Used by for example gets(). #ifdef ICC8051 int getchar(void) #else /presume C51 or other accepting compilator/ char getchar(void) #endif { return hal_uart_getchar(); }
// Repeated putchar to print a string void putstring(char *s) { while(*s != 0) putchar(*s++); }
void main(void) { // Configure TXD pin as output. // P0.5, P0.3 and P1.0 are configured as outputs to make the example run on // either 24-pin, 32-pin or 48-pin nRF24LE1 variants. P0DIR = 0xD7; P1DIR = 0xFE;
// Initializes the UART hal_uart_init(UART_BAUD_9K6);
// Wait for XOSC to start to ensure proper UART baudrate while(hal_clk_get_16m_source() != HAL_CLK_XOSC16M) {}
// Enable global interrupts EA = 1;
// Print "Hello World" at start-up putstring("\r\nHello World!\r\n");
for(;;) { // If any characters received if( hal_uart_chars_available() ) { P3 = 0x11; // Echo received characters putchar(getchar()); } } } /** @} */
